Couple of questions about the 2bar map sensor - Boost Forum
Monday, January 16, 2006 2:59 PM
Ill be turboed soo and had the following questions.
1. Is it NECESSARY to run this 2bar with a fully built engine and turbo kit? Or will the stock one be fine?
2. If I do need the 2 bar, will it work with my 99 non egr wiring harness?
3. When is the 2bar necessary to use?
Please help with my confusion! Thanks.
Re: Couple of questions about the 2bar map sensor
Monday, January 16, 2006 3:05 PM
You can only use the 2 bar on 2000+ 2.4's with the GM S/C reflash.
The 2 bar MAP will ONLY work if you have the GMSC reflash or another reflash that allows the ecu to interpret the 2bar vs. the stock 1bar signal. Whether you need it or not all depends on how you plan on tuning the car, but if you're not flashing the ecu, you can't use the 2bar MAP.
Monday, January 16, 2006 3:07 PM
Thanks guys, in a nutshell you've pretty much answered what I needed to know. Im not getting the reflash so I guess I can't use it.
So ill be fine with the standard 1bar right?
Monday, January 16, 2006 3:12 PM
You don't have a choice, you'll need to be just fine with it
Monday, January 16, 2006 3:14 PM
lol, rub it in why don't ya
Monday, January 16, 2006 3:56 PM
Keep in mind your regular sensor is only meant to see vacuum, it will go nuts if the sensor sees boost. Alot of people put a check valve of some sort in the vacuum line.
............super 60 on its way
Monday, January 16, 2006 4:01 PM
purplhaze wrote:Keep in mind your regular sensor is only meant to see vacuum, it will go nuts if the sensor sees boost. Alot of people put a check valve of some sort in the vacuum line.
It won't go nuts, some people get away with it, some don't. Mine hasn't complained yet.
Monday, January 16, 2006 4:11 PM
yea mine either
Monday, January 16, 2006 5:34 PM
Not true. The Map sensor will reach the 5v maximum at 0psi. It can't go crazy, it has already reach it's maximum. The reading will not go higher even if you put 100psi on the map sensor.
Gilles
2.3 Ho
Monday, January 16, 2006 6:29 PM
well, you still want the stocker off mine david?
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
Monday, January 16, 2006 7:11 PM
ZStreetCavSC(Whinin) wrote:well, you still want the stocker off mine david?
Suuuure, doooo
