msd inline - Boost Forum
msd inline
Tuesday, December 20, 2005 9:52 AM
i searched and didnt find what i want. i need to kno which terminal on the fuel pump realay that i hook my inline pump to. i saw a while ago that someone had pics and it said to hook it up to the 30 or 32 lable or somethin like that. i hope u all understand what im talkin about.
DRIVE HARD OR DONT DRIVE AT ALL!!!
Re: msd inline
Tuesday, December 20, 2005 2:45 PM
any 1?
Re: msd inline
Tuesday, December 20, 2005 2:58 PM
i would use the wire off the relay that feeds the power to the pump to turn on another relay for the inline pump
this way the pcm only has to turn on the stock relay , and wont over load its low output signal
also it means you have double protection on the external pump , if the stock fuel pump happens to blow its fuse neither pump will work , incase there is a major problem
that is how i hooked up my friends external pump , i tapped his in at the wires under the relays , in the box next to the battery under the hood
Re: msd inline
Wednesday, December 21, 2005 2:48 PM
ok well i tied the external pump in with the grey wire. and now the car bogs around 3g, or when i hit boost. it wasnt doin this before so i think that the wire i tapped into might b wrong. can someone tell me if its the right one or not. or which color wire i tap into. 01 2200 cavy
Re: msd inline
Wednesday, December 21, 2005 4:12 PM
Back when i had my vortech inline fuel pump,my car would bog out on me when i was below 1/4 of a tank.If i drove it easy it would be fine,but as soon as i romped on it,it would bog out.Just put some more gas in your tank and see if it stops bogging.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
Re: msd inline
Thursday, December 22, 2005 7:20 PM
yea puttin more gas in it fixed the prob. i dont understand y but it did.
