ok few questions... - Boost Forum
ok few questions...
Tuesday, November 22, 2005 10:09 PM
Ok Ive decided to just go turbo instead of getting the gm charger for the reflash. I know the basics about tuning and everything but my question is. Am I going to need a check valve since the stock map sensors doesnt see boost. Im only going to do like 5 to 10psi intercooler so is a msd ignition control going to be needed? The turbo im planning on going with is a t3 super 60 till i rebuild the motor.
Re: ok few questions...
Wednesday, November 23, 2005 6:38 AM
Megasquirt it. MAP sensor included
Wednesday, November 23, 2005 6:23 PM
what he said /\
Thursday, November 24, 2005 1:51 AM
dont have enough knowledge to use it. So yea like i asked would i need a check valve cause im trying to save money till I go and rebuild my motor.
Thursday, November 24, 2005 5:02 PM
I just picked up oil lines, manifold, and bov and few other things
Thursday, November 24, 2005 10:39 PM
Im planning on going with this turbo from agpturbo.com clicky im planning on going with a .48 a/r.... how is that going to be im looking for full spool about 3-4k rpms....... still looking for information about the check valve but im probably going to go with emanagement since i cant get much information on use with check valves. plus i thought im going to need something for timing control
Thursday, November 24, 2005 11:10 PM
I'd do the .63 turbine a/r honestly. Do a PnP and secret cams and it'll be sweeeeeeeeeeeet
Friday, November 25, 2005 12:21 AM
ok thats was my first thought for a/r but then i thought i would go a lil smaller but i guess that would be better for what im looking for.
Friday, November 25, 2005 7:39 AM
Z Speed Cavi wrote:ok thats was my first thought for a/r but then i thought i would go a lil smaller but i guess that would be better for what im looking for.
well there's a lot of room between .42 and .63 a/r lol but the .63 would be my recommendation at this point
Friday, November 25, 2005 7:57 AM
look up speedracerz. he is in your area and can get the computer reflashed with the GM s/c program. he has done a bunch.
then u would need the gm s/c map sensor and maybe the injectors and you are off to a good start.
and exploited racing is down there in west allis. he could help you out.
Friday, November 25, 2005 8:12 AM
Z Speed Cavi wrote:Ok Ive decided to just go turbo instead of getting the gm charger for the reflash. I know the basics about tuning and everything but my question is. Am I going to need a check valve since the stock map sensors doesnt see boost. Im only going to do like 5 to 10psi intercooler so is a msd ignition control going to be needed? The turbo im planning on going with is a t3 super 60 till i rebuild the motor.
Just get your PCM reflashed to the GM s/c program, along with the injectors and map sensor from the kit as well and you won't need a check valve on the map or the MSD to pull timing, or other fuel mods.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Saturday, November 26, 2005 4:41 PM
talk to brian hes gonna help me with the gm reflash when him and me get time. So then the hardest part has been solved for me. rest just relys on money, time, and patience for me.
