building turbo manifold - Boost Forum
Friday, November 18, 2005 11:16 AM
Hey guys, I'm thinking of going back into boost, but this time I want to do everything right and have it be the best kit I every design. Anyways some question about the turbo manifold. I'm going to buy the manifold flange and some schedule 40 bends to weld up my manifold, the question is, I know there will be 2 90 degree bends, 2 "T" bends for the 4 exhaust ports. Instead of using 2 X "T" bends, can I use a "+" bend which will allow me to attach the turbo inlet flange to one of the 4 ports? I hope this does not restric much of an exhuast flow more than it being a log style....
Also, for the exhaust flange, I'm directing it down toward the ground so the turbo will be bolted "up" to the manifold from the bottom, I'm going to use a "T" off the port so one is for the flange and one is for wastegate, guys think this will work?
Where can I get the exhaust manifold flange for the cheapest?
Re: building turbo manifold
Friday, November 18, 2005 4:58 PM
You could probably use a +
but the outlet to the turbo flange would have to be bigger than 1 1/4" .
Saturday, November 19, 2005 11:54 AM
just buy one
Saturday, November 19, 2005 3:14 PM
ebay has the flanges both of them, wait which motor
Sunday, November 20, 2005 9:58 PM
2200
Sunday, November 20, 2005 10:35 PM
ya ebay even has stainless flanges for the 2200!!
that is what I was going to do ......... expensive....
good luck.... better be s.s.....
Lee
JDM Civic Hatch
Monday, November 21, 2005 8:10 AM
ya, sounds like a good idea to just buy one, or weld a flange to ur stock manifold it will never crack.
Monday, November 21, 2005 10:59 AM
welding on cast iron???
Monday, November 21, 2005 12:52 PM
I dont think the whole thought process went through on that comment id just cut him some slack Buying one is so easy. And its not like they are to expensive.
*2012 mazdaspeed3*
Monday, November 21, 2005 2:51 PM
Respooled2k3 wrote
But that takes out the fun part.
Thursday, November 24, 2005 1:58 PM
ya you can weld right to it i know..... because my turbo manifold is made from my factory one. just make sure to use high heat. i wish the digital camera was around i'd show u a pic.
Thursday, November 24, 2005 3:41 PM
not a good picture.
Thursday, November 24, 2005 6:36 PM
or you can mount the turbo on the header w/ it collects and bolts up to the downpipe persay..... i made an adapterplate for mine, it bolts up and turbo sits to the left of the engine, plenty of room, not in plain sight.... very cheap to do
i got a sig warning
boosted cavfire
