Who all makes 2.4L turbo kits? - Boost Forum
Thursday, November 03, 2005 10:39 PM
Ok i am looking into getting a turbo kit for my car... ahah big plans are going into this... most of you will probably catch on right away but yea does Hahn make one for my car? if not who is my best bet?
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
Re: Who all makes 2.4L turbo kits?
Thursday, November 03, 2005 11:13 PM
The only one you need to concentrate on is JTuners.
Friday, November 04, 2005 3:30 AM
dont leave out the guys at maximum boost... yea they had a few ruff edges at first but there starting to grind down and do business.
Friday, November 04, 2005 7:39 PM
Spotabee Racing wrote:The only one you need to concentrate on is JTuners.
Yea i have been looking at theirs... i can get an intercooler with that kit? also i wont need alot of the parts...
Friday, November 04, 2005 7:40 PM
are you planning on running the s/c with the turbo............. ???? that would be kinda crazy... I'd give that some respect....
Lee
JDM Civic Hatch
Friday, November 04, 2005 10:21 PM
ahah yes.... but i dont wana make a big deal of it yet... so unless people see in here keep it quiet.... but it will start off with only a turbo and supercharger and then when i get the money again it will be a fully built engine, ported head and ported supercharger...
Saturday, November 05, 2005 2:44 AM
Josh im impressed Actually i've been shooting around this idea since before i got my s/c. My engine is now fully built and i have pretty much every mod i can get including the s/c. A couple weeks ago my shop and I began doing a mock up of a turbo kit on top of my s/c however more research needs to be done, the preliminary numbers dont really vote well for having this setup be as effective or as efficient as one would think, the GM s/c will only flow so much air and then the heat issues at this point pose a huge problem, even with an intercooler and alky injection the intake air is going to be alot hotter than normal not to mention the new issue of raised EGT's. Regardless im going to keep moving forward and hopefully by spring will have a working mock up to see if this will actually produce any solid numbers. Tuning is a whole new story im thinking theres really no way to do it except standalone. Anyways prop on the ingenuity man im right there with ya.
607 Motorsports is your one stop performance and car specialties shop, we can do anything your imagination holds. Check us out at www.cardomain.com/id/jimmyc99z24
Saturday, November 05, 2005 2:52 AM
there shouldnt be that much more tuning involed should there? i mean the boost is all going into the same place... its more tuning the turbo to what boost it should be at...and picking the right sized turbo for what ever the CFM that the s/c'er is capable of..
As for cooling.. say i run 5psi of boost on the turbo...this isnt that high and with the intercooler it should cool it right down with the low boost... and the alcohol was cooling my supercharger VERY cold so the charged air temps shouldnt be all that bad?
and we also have the reflash that all the turbo people seem to love any way so that part should be fine... only thing different with my fuel i am doing is 440cc injectors, and the walbro high flow pump...
Saturday, November 05, 2005 8:34 AM
Josh whats a very cold iat in your opinion...
my buddys tsi is running -12 C IAT at idle with his stock intercooler.... how cold were you .... remember turbo is SUPER hot.... that is why when people ask if an intercooler is a must most people say YES ....
Lee
JDM Civic Hatch
Saturday, November 05, 2005 10:09 AM
imo i would just switch over to a turbo kit, the only reason for keeping the SC on there would be for the bling factor, and im pretty sure you don't care to much about show. i think you would run alot more efficent and probably faster with just a nice turbo setup. not too mention selling the SC would pay for most of that turbo setup, with all the money left over you could build your motor up and run alot more boost
Saturday, November 05, 2005 11:48 AM
Derek - ahah yea you know me to well as i never go for just "show" stuff but in this case i kind of want to... and if you think about it with the supercharger ported it will be able to flow more any way... and im not going with a big turbo any way.. later on i might just convert it to a single turbo only set up.. but i want to see how this goes cuz think about it... the supercharger will to some extent pull the air threw the turbo spooling it faster... and the supercharger will still be there for off the line stuff.. but it dies down in top end stuff and by then the turbo will be spooled to finish it all off
Lee - not sure what i would say is cold at idle since i got no gauge for that... but i know turbos make HUGE! heat hence why i am doing every thing i can too cool it down...this set up will be hard to do.. but not only are me and my dad up for it.. but i have talked to people about the tuning and they are all for it ... so it will be fun
Sunday, November 06, 2005 2:22 PM
gut the s/c and use it as a huge intake manifold like GTP guys do..
BeardLife / Club Awesome Reject Blog
Sunday, November 06, 2005 3:55 PM
Qwik2k2z24 wrote:gut the s/c and use it as a huge intake manifold like GTP guys do..
and i am guessing they just pull the pulley end off and block it off?
well right now with all these calculations of air temp/pressure and 100's more that my dad is working on.. it will be around 275hp at the wheels with 7psi from the turbo and the stock 2.8" pulley on the supercharger (7psi from the turbo but a 2psi loss from the charge pipes)
And our problem is finding a turbo that flows enough air... none of the T3 turbos flow enough... were arent even close on the turbo maps for them.. I am looking for somthing that will flow 40 lbs/min at a compression ratio of 1.49...
Sunday, November 06, 2005 6:35 PM
yes the nose cone is removed and blocked off.
Sunday, November 06, 2005 6:53 PM
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Sunday, November 06, 2005 9:59 PM
Skilz10179 wrote:
mmmmmmmmmmmm sleeper......... buick ??? sweet.....
Lee
JDM Civic Hatch
Sunday, November 06, 2005 10:00 PM
I just don't get why? because like i said before my supercharger isn't even a restriction on this... actually its very hard to find a turbo that will flow enough air ..... and at 7psi on the turbo and the stock supercharger pulley i will be making like 270whp...where as if i blocked off the supercharger and had it as an intake and only 7psi on the turbo i even be close to 270hp
Monday, November 07, 2005 12:40 AM
not to jack the post but the JTuners kit makes the engine bay look ugly.
Monday, November 07, 2005 8:13 AM
I would imagine you would have some efficiency problems.........
get em figured out build that motor and run 450 hp ..... and SMOKE that srt-4 you raced.... that was you right josh ???
Lee
JDM Civic Hatch
Monday, November 07, 2005 9:31 AM
if u can make it work then more power to u..
Monday, November 07, 2005 12:03 PM
Derek Z24 wrote:imo i would just switch over to a turbo kit, the only reason for keeping the SC on there would be for the bling factor, and im pretty sure you don't care to much about show. i think you would run alot more efficent and probably faster with just a nice turbo setup. not too mention selling the SC would pay for most of that turbo setup, with all the money left over you could build your motor up and run alot more boost
I agree 110%.
Monday, November 07, 2005 12:13 PM
I agree 110%.
LE61T PTE6262 Powered
Monday, November 07, 2005 3:58 PM
ahah man soo many doughters... this sucks... i would think people would be more for it... oh well i hope i can prove every one wrong... not saying i will but wow it will feel nice if/when i do
Lee - yea that was me against my buddys SRT-4... but he has soo much more going into it this winter as well
Monday, November 07, 2005 4:31 PM
no one said it CANT be done, it would just be cheaper, and more than likely alot quicker by ditching the SC all together and building a nice turbo kit... but if thats what you want to do good luck, just think you would be much better off the other way
Monday, November 07, 2005 4:47 PM
i hope ur determination going into this project is as high as ur confidence in proving everyone wrong.
