2 bar map sensor ? - Boost Forum
2 bar map sensor ?
Friday, October 28, 2005 10:09 AM
i was wondering if you need to get a gm 2bar map sensor im hooking up a msd dis -2 for timing retard someone said i need the sensor to do this . is this true ? if so anyone have a part # for it ? where to get it? thanks
13's or blowning it. one way or the other!
Re: 2 bar map sensor ?
Friday, October 28, 2005 2:15 PM
i doubt it since the computer isn't programmed for a 2bar, but someone correct me if i am wrong
cavaliers been laid to rest
The saturn is being born
a new cavalier is in the mist
Friday, October 28, 2005 4:56 PM
Nope you do not. If you do, then you would need programming such as a reflash for the 2 bar. Having the sensor only does you good if the PCM can understand it
Saturday, October 29, 2005 8:38 PM
I was under the impression that with the MSD dis 2 digital that you could use a map sensor to retard ignition timing in proportion to boost? Is that not true?
Saturday, October 29, 2005 8:58 PM
you'll have to get the msd map sensor and put a hose on it and tap it into your intake manifold somehow or just something that sees boost. keep your stock one where it is.
Sunday, October 30, 2005 12:34 AM
yep... but note, you need the dis-2 programmable for this.
Sunday, October 30, 2005 8:27 PM
rob (the one with the vette) wrote:yep... but note, you need the dis-2 programmable for this.
Thats the one the programible.
