What is Map Unit(Black Box) Turbo? - Boost Forum
Thursday, October 27, 2005 2:10 PM
I was wondering if anybody new what a Map Unit(Black Box) is that you need for a turbo? I am putting together my own turbo, and everything is going well, but this is the only thing that I am lost for words for. I plan to only run 8psi. And also, if anyone has any pictures of the Black Box, and pictures of there turbo setup please post so I can get idea of how it looks also.
Thanks
Re: What is Map Unit(Black Box) Turbo?
Thursday, October 27, 2005 2:22 PM
Are you talking about the map sensor? its right in front of the expansion box on the 2.4 if you need the part # for the GM Map Sensor it is GM PART # 9350899......... GM LIST: $240.16/OUR PRICE: $120.08 on gmpartsdirect.com
hope that helps but I am not totaly positive on what you are asking
Thanx Charles
Thursday, October 27, 2005 2:38 PM
Thanks for a quick response Charles, but I think that is it. I have a 2.2L engine. And I was wondering if an upgraded Map Sensor was needed to run on the turbo, if so where do I get the upgrade version to run for my turbo?
thanks
Thursday, October 27, 2005 6:20 PM
you dont need an updated 3-5 bar map sensor as your computer is not trained to understand boost in relovation to boost, spark and fuel curvs. All you need to do is "bleed" off boost with a series of check valves.
Thursday, October 27, 2005 10:03 PM
Oh didnt look at your reg......Ya that MAP that I gave you is only for the 2.4 with the Reflash...... but what Ron said you will have to use check valves so your computer wont see boost.
Thanx Charles
