bad move....
sorry to be the buzz kill here...
they are a little small.... you can run like 3 psi safely..... anything more I'd be worried about the injectors clipping...... thats just me... too much fuel is better... then you can back it off with a AFPR... and get a really good tight tune.....
I was running 32 lbs bosch injectors...on 7 psi and I was lean.... moved up to brown tops..(36 lbs)
Good luck......
Lee.
JDM Civic Hatch
you'll be fine for 6 psi on these if you are on stock bottom end on a good tune.
well you make the buy out to be whatever you want.... sportabee says 6 psi.... I said 3psi... so you know that your limits are rather small............. fmu is good... but I'm saying get bigger ones and get an adjustble fuel pressure regulator.....
you'll be safe and have peace of mind...
Lee
JDM Civic Hatch
like i said i only plan on running 6 psi tops. this sucks if they wont work.
well they might be okay but to be completely honest with you I'd feel bad to tell you to try them knowing that my 32lbs ones were leaning at 7 psi..... I also drive a 2200 boosted.....
so you do what you'd like but a 32lbs injector would be the best for 6 psi... for safety and reliablility...
Lee
JDM Civic Hatch
well damn ii guess i got lucky tho, i contacted the seller and he said he doesnt have a problem beings that i was the only bidder. now i need some injectors to run 6 psi i guess.
ya get 36lbs brown tops and get a AFPR and you'll be good to go ....
Good luck ...
Lee
JDM Civic Hatch
Will any 36# injectors work? how do i know if they are the "brown tops" and where is the best place to find them for the cheapest price?
I have some for sale in the calssifieds
Save a Tranny, Roll-on
15.3@88m.p.h.(I/E)
15.2@94m.p.h.(S/C'd)
15.5@89m.p.h.(Stock GTP)
i run these injectors(stock 98z224 injectors) at 5psi of boost, and a cartech FMU and walbro pump for a year on a 2.4l. Dont tell me about clipping.
he wanted 6 psi
.... stock injectors just aren;t trust worthy to me .......
sorry I can't get my head around it ....
Lee
JDM Civic Hatch
So... what size are stock 2.2 ecotec injectors?
Lee wrote:he wanted 6 psi
Lee
I would rather be safe than sorry, plus who is to say that i may get antsy at the track and want to up it a few pounds a few times?
Vincent as long as your vehicle required a low impedence Injector the Brown tops are for you...... If it requires a high impedence injector ... No good...
Lee
Hey Eben... how those Coil overs coming ??
Let me know...
JDM Civic Hatch
I have a 2000 Cavalier with a 2200 SFI so i dont know what impedence i have or what that really means I guess.
i think you have high impedence.
you can't use his injectors....
Vincent... your in the same boat as me......
2000+ had a different pcm... you must have High impedence.....
the brown tops are low impedence....
Lee
JDM Civic Hatch
now tell me what i have. 99 2200. because i heard both high/low?
is there anyway to test them to find out? like with a ohm meter or something?
ya of course you could test em.... however i don't know the parameters of high and low.... so you'd have to find that out yourself ....
Lee...
JDM Civic Hatch
