ppl with ecos boosted what plugs you running? - Boost Forum
Tuesday, October 04, 2005 3:23 PM
ive heard conflicting info on this and have stuck with the stock plugs with various gaps anywhere from .030 all the way to .050 with and without the msd and I still get the 0300 misfire code im specifically interested in the NGK or Denso or the autolite 103s
Re: ppl with ecos boosted what plugs you running?
Tuesday, October 04, 2005 4:19 PM
I am using the stock plugs gaped at .045 no miss fire codes. i have had the plugs out a few times to check them no signs of over heating.
Thats Him Officer The WICKED One.
Tuesday, October 04, 2005 4:56 PM
autolite 103's..gapped at what my stocked one's were gapped when i took them out.
gapped @ .060 No missfire code yet. 10k miles @ only 5 PSI non intercooled.
Tuesday, October 04, 2005 5:40 PM
i currently have stock plugs (ac delco) in it which i replaced when i got boost ive tried gaps anywhere between anywhere from .030 all the way to .050 and its always a problem, im thinking maybe i need a different type of plug i dismissed it as a possiblity in the past but im open to any options to solve this code 300 random/multiple misfire
Tuesday, October 04, 2005 5:50 PM
103s gapped at .025. get rich misfire codes 85% of the time when i make a quarter mile pass. the stock ignition is no good above 4200RPM at 10PSI or higher. Just cant keep up. PERIOD.
5K PB: 24:50
10K PB: 54:26
Tuesday, October 04, 2005 6:37 PM
hmm maybe its time for the msd programmable
Tuesday, October 04, 2005 6:42 PM
Stock plugs gapped somewhere around .032. No misfire codes at all.
Tuesday, October 04, 2005 6:52 PM
In my case......NGK TR6's (4177) gapped at .032 = No missfire codes anywhere from 5psi to 12psi. When gapped at .035 I had multiple cylinder misfires. I find it interesting some people have the gap as large as .060 I thought the boost pressure would blow the spark out.
Tuesday, October 04, 2005 7:01 PM
autolite 103's at .035"
LE61T PTE6262 Powered
Tuesday, October 04, 2005 7:03 PM
I have an msd on now so i do have a stonger spark, how can one tell if its getting blown out
Tuesday, October 04, 2005 7:59 PM
it probly is not getting blown out if youre running lean...
Thursday, October 06, 2005 10:04 AM
whats the proper ngk irriduim plug part # for the eco
