Turbo Driveability poll: T3 or T3/T4 - Boost Forum
Tuesday, October 04, 2005 4:16 PM
Sup guys.
My goal if I go turbo is about 220 whp. Both turbos can get me there reliably. But I want to be able to stay off boost when I want to. Say lower than 2500 rpm I'd like to stay off boost. Which turbo should I get ? I think there are other variables like trim but I'm not too good with these details. If you wish to educate me go ahead.
Thanks for your input !
15.891 @ 88 mph stock, still getting @!#$ty launches...
Re: Turbo Driveability poll: T3 or T3/T4
Tuesday, October 04, 2005 5:12 PM
A 60 trim T3 with a .48 turbine a/r should be a great sized turbo for your needs. It will support up to 300hp if you feel the need for more power down the road and should provide near instant boost when you mash down the pedal. You should be able to stay off boost all day long with just about any sized turbo, its all a matter of how much throttle you give it rather than rpm. In theory you should be able to drive down the street in 1st gear at 5,000rpm with only giving 5% throttle and still not be making any boost....
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Tuesday, October 04, 2005 5:23 PM
Skilz10179 wrote:A 60 trim T3 with a .48 turbine a/r should be a great sized turbo for your needs. It will support up to 300hp if you feel the need for more power down the road and should provide near instant boost when you mash down the pedal. You should be able to stay off boost all day long with just about any sized turbo, its all a matter of how much throttle you give it rather than rpm. In theory you should be able to drive down the street in 1st gear at 5,000rpm with only giving 5% throttle and still not be making any boost....
What he said. Perfect turbo.
Tuesday, October 04, 2005 5:53 PM
They're both good answers but I'm happy with my T3/T4 although I really do not drive it alot.
Tuesday, October 04, 2005 7:06 PM
That's nice to hear. You see we have harsh winters here in quebec (-40 celsius) and I would be running my turboed sunfire in the winter. So all I have to ask when shopping for the turbo is a Garret (i think) T3 .48 turbine a/r ?
Tuesday, October 04, 2005 7:08 PM
oh yeah this is also for a setup with stock internals. will I attain 220 whp on a reasonable daily use PSI setting ? I'm guessing anywhere from 8 to 10 psi. I will also have full 2.5" exhaust. But the rest will be mostly stock if you exclude what is necessary in a turbo kit like intercooler and fuel mods + HP Tuners software
Tuesday, October 04, 2005 7:37 PM
that's what I'll be using.
Remember if you dont put a lot of load on the engine, you wont be in boost.
Tuesday, October 04, 2005 7:46 PM
DanteMustDie wrote:oh yeah this is also for a setup with stock internals. will I attain 220 whp on a reasonable daily use PSI setting ? I'm guessing anywhere from 8 to 10 psi. I will also have full 2.5" exhaust. But the rest will be mostly stock if you exclude what is necessary in a turbo kit like intercooler and fuel mods + HP Tuners software
To get to 220 whp you'd most likely be around ~240 hp @ the crank. I think these car's have like 140 hp @ the crank to begin with so if you can acheive that significant of a performance increase with something as simple as a T3 or Hybrid T3 turbo @ 10# that would be crazy. I was running 20# on my T3/T4 on my TBird Turbocoupe with full 2.5" exhaust, ported exhaust manifold, no cats, dynomax ultraflow mufflers, roller chamshaft, gillis boost valve & quite a few other things and didnt see that type of increase in power.
2004 Cavalier Coupe 18" Miglia Ravia's, black/grey.
Tuesday, October 04, 2005 7:48 PM
actually I'm pretty sure plenty of people on the jbo have done it without a problem. if we're lucky they will post to prove what I'm saying
Tuesday, October 04, 2005 9:14 PM
You should be able to get in the 220 whp range with 10-12 lbs. of intercooled boost and a good tune.
Tuesday, October 04, 2005 9:26 PM
you should get 220 whp from a t3 super 60 at probly 7-8 psi.... with tuning...
LE61T PTE6262 Powered
Wednesday, October 05, 2005 1:19 AM
yeah, 8psi intercooled would be an easy 220. people running 8 on hahn kits have seen over 230, and hypsy, running 15psi on STOCK INTERNALS, sees high 12s and over 300 horses.
Wednesday, October 05, 2005 3:35 AM
Skilz - I CAN'T stay off boost with my Gtz. even if I give it 5% throttle. I get boost as soon as I step on the gas. But of course it's on an HO engine.
Gilles
2.3 Ho
Wednesday, October 05, 2005 5:10 AM
^^^listening... what is the truth about this ? I don't think the fact that it is a HO engine would make it so different to an eco, aside from obvious power differences, why wouldn't the HO engine be able to stay out of boost ? If I can,t stay off boost, I will definitely get a bigger turbo so it doesn't spool up until 2500 rpm.
Wednesday, October 05, 2005 5:19 AM
I'm running a 60 trim t3 and I can vouch for it being a good choice. i started at 5lbs, was there for a while, then went to 7 and I am now at 10. The turbo is a pretty good match for the eco. When I want boost it comes in at just over 2000 rpm and I'm at full boost by 2800. At the same time if i want to (which isn't very often) all that's needed to stay in vac is keep the throttle below 50% generally speaking.
Car is going on the dyno next weekend, so we'll see what it puts down then, but so far at 7psi at the track I was babying it and still went 14.2 @99.6mph. That's going super easy out of the hole and shifting like my grandma would
<img src=http://home.comcast.net/~richnj221/smiley.gif>
Wednesday, October 05, 2005 12:17 PM
an Ho engine flow alot more than an eco. The displacement is higher, bigger cams, ...
My turbo is a T3/T04E. .48 exhaust side and .70 compressor side. I get boost @ 1500rpm and I have full boost @ 1700rpm.
Gilles
2.3 Ho
Wednesday, October 05, 2005 12:26 PM
DanteMustDie wrote:^^^listening... what is the truth about this ? I don't think the fact that it is a HO engine would make it so different to an eco, aside from obvious power differences, why wouldn't the HO engine be able to stay out of boost ? If I can,t stay off boost, I will definitely get a bigger turbo so it doesn't spool up until 2500 rpm.
it's all about CFM and compressor maps. you just have to figure out what turbo, based on how much your motor is pushing out, what will spool best based on your powerband, etc etc
Wednesday, October 05, 2005 12:34 PM
All of this information has made me exicted. I had no idea that these little car's were capable of getting so much out of a simple turbo. I can't wait till my warranty runs out
Wednesday, October 05, 2005 12:35 PM
illwill wrote:All of this information has made me exicted. I had no idea that these little car's were capable of getting so much out of a simple turbo. I can't wait till my warranty runs out
it's not exactly easy and cheap... but with boost it doesn't take a fully built motor to hit 13s
Wednesday, October 05, 2005 3:47 PM
It helps when you've work in a company building turbos for the military. alot of choice.
a really small turbine housing for fast spool and a really BIG compressor for alot of CFM. Only problem is, I tough the turbo would spool later but it's spooling really soon. It's a bit annoying in town going 30 in 3rd gear and having the BOV blowing off all the time.
Gilles
2.3 Ho
Wednesday, October 05, 2005 5:03 PM
Mfk-223 wrote:Skilz - I CAN'T stay off boost with my Gtz. even if I give it 5% throttle. I get boost as soon as I step on the gas. But of course it's on an HO engine.
I would have to see that to believe it.....
Wednesday, October 05, 2005 5:30 PM
Then I gotta put the car back together ASAP and send you a vid of it.
Gilles
2.3 Ho
