SAFC + P0107 + resistor = CEL remains - Boost Forum
Sunday, August 14, 2005 8:47 PM
First this is on a 96 grand am, 2.4 5 speed with a turbo setup
Alright guys, I need some help here. I just put the SAFC in my car yesterday and got it all setup. I drove it yesterday and the SAFC was doing exactly what it was supposed to be, but then about 10 minutes into drive I get a code, check it, P0107! This is the most annoying code ever... EVER.
So I say ok, try a resistor. So today I put a 330 ohm resistor on there. Now the car runs real rich at idle while I had it tuned to a nice idle before. I drove the car for about an hour with no code. I drive to autozone, go in for some stuff. Go to leave, start car and CEL is on immediately. WTF!!!! My map voltage, I can watch it on the SAFC never EVER goes below 1.4 volts now and this is making absolutely no sense (unless the -% compensation at idle on the SAFC is making the out voltage go to <.2 volts, but I doubt it.. I'm getting so freakin pissed here has anyone else had and solved this? My a/f ratios are good until that damn CEL comes on.
Without the emanage or SAFC installed I get NO CEL's! So what gives?!?! Someone PLEASE help me
Thanks
-Bob
Re: SAFC + P0107 + resistor = CEL remains
Monday, August 15, 2005 9:37 AM
Alright I got another idea I'm going to try today if I can. Does anyone have a pin-out for the 96 2.4 ECU? That would be extremely helpful.
Wednesday, August 31, 2005 3:36 PM
Wednesday, August 31, 2005 3:46 PM
Anyone have the schematic for the Eco? Thanks in advance!
Wednesday, August 31, 2005 3:55 PM
EcoTec
Powertrain Control Module (PCM) Pin Layout
Connector Part Information • 15357150
• 56-Way F Micro-Pack 064 Series (BLU)
Pin Wire Color Circuit No. Function
1-3 -- -- Not Used
4 PPL 420 TCC Brake Switch/Cruise Control Release Signal
5-6 -- -- Not Used
7 BLK 2760 Low Reference
8-10 -- -- Not Used
11 BLK 2759 Low Reference
12-14 -- -- Not Used
15 PPL 1807 Class 2 Serial Data
16 PPL 1807 Class 2 Serial Data
17-18 -- -- Not Used
19 PNK 639 Ignition 1 Voltage
20 ORN 480 Battery Positive Voltage
21 TAN 472 IAT Sensor Signal
22 PPL 1589 Fuel Level Sensor Signal
23 GRY 2700 5 Volt Reference
24 -- -- Not Used
25 GRY 2709 5 Volt Reference
26-32 -- -- Not Used
33 BRN/WHT 419 MIL Control
34 DK GRN/WHT 817 Vehicle Speed Signal
35-36 -- -- Not Used
37 RED/BLK 380 A/C Refrigerant Pressure Sensor Signal
38 -- -- Not Used
39 DK GRN 890 Fuel Tank Pressure Sensor Signal
40-42 -- -- Not Used
43 DK GRN 335 Cooling Fan Relay Control
44 -- -- Not Used
45 WHT 1310 EVAP Canister Vent Solenoid Control
46 DK GRN/WHT 465 Fuel Pump Relay Control
47 DK GRN/WHT 459 A/C Compressor Clutch Relay Control
48 -- -- Not Used
49 DK GRN 83 Cruise Control Inhibit Signal
50 -- -- Not Used
51 BLK 2751 Low Reference
52-56 -- -- Not Used
Connector Part Information • 15357133
• 73-Way F Micro-Pack 064 Series (BLK)
1 LT BLU/BLK 1748 IAC Coil A Low Control
2 LT BLU/WHT 1747 IAC Coil A High Control
3-4 -- -- Not Used
5 DK GRN/WHT 428 EVAP Canister Purge Solenoid Control
6 RED/BLK 1228 PC Solenoid Valve High Control -- Sol. A Automatic Transmission Only
7 LT BLU/WHT 1229 PC Solenoid Valve Low Control -- Sol. A -- Automatic Transmission Only
8-9 -- -- Not Used
10 LT GRN 1222 1-2 Shift Solenoid Valve Control -- Automatic Transmission Only
11 YEL/BLK 1223 2-3 Shift Solenoid Valve Control -- Automatic Transmission Only
12 BRN 418 TCC PWM Solenoid Valve Control -- Automatic Transmission Only
13 PPL/WHT 1668 HO2S High Signal Sensor 2
14 TAN/WHT 1669 HO2S Low Signal Sensor 2
15 TAN 1667 HO2S Low Signal Sensor 1
16 PPL 1666 HO2S High Signal Sensor 1
17 LT GRN/WHT 1749 IAC Coil B High Control
18 LT GRN/BLK 444 IAC Coil B Low Control
19 WHT 423 IC Timing Control A
20 ORN 406 IC Timing Control B
21-25 -- -- Not Used
26 BRN/WHT 633 Camshaft Position Signal
27 YEL 573 CKP Sensor 1 Signal
28 PPL 574 Low Reference
29 LT GRN 432 MAP Sensor Signal
30 -- -- Not Used
31 DK BLU 417 TP Sensor Signal
32-33 -- -- Not Used
34 WHT 776 Transmission Range Switch Signal P
35 GRY 773 Transmission Range Switch Signal C
36 YEL 772 Transmission Range Switch Signal B
37 BLK/WHT 771 Transmission Range Switch Signal A
38 -- -- Not Used
39 BLK 2761 Low Reference
40 BLK 2762 Low Reference
41 DK BLU/WHT 1231 AT ISS Low Signal -- Automatic Transmission Only
42 PPL 401 Signal Low-Front
43 -- -- Not Used
44 GRY 1716 Low Reference
45 ORN/BLK 469 Low Reference
46 -- -- Not Used
47 BLK 2752 Low Reference
48 -- -- Not Used
49 GRY 23 Generator Field Duty Cycle Signal
50 RED 225 Generator Turn On Signal
51 BLK 1744 Fuel Injector 1 Control
52 LT GRN/BLK 1745 Fuel Injector 2 Control
53 LT BLU/BLK 396 Cruise Control Engaged Signal
54 TAN/BLK 231 Oil Pressure Switch Signal
55 PNK 1224 Transmission Fluid Pressure Switch Signal A --Automatic Transmission Only
56 DK BLU 1225 Transmission Fluid Pressure Switch Signal B -- Automatic Transmission Only
57 RED 1226 Transmission Fluid Pressure Switch Signal C -- Automatic Transmission Only
58 YEL 657 TCC Release Switch Signal -- Automatic Transmission Only
59 YEL 410 ECT Sensor Signal
60 YEL/BLK 1227 TFT Sensor Signal -- Automatic Transmission Only
61 RED/BLK 1230 AT ISS High Signal -- Automatic Transmission Only
62 YEL 400 Signal-High Front
63 -- -- Not Used
64 DK BLU 496 Knock Sensor Signal
65 GRY 2704 5 Volt Reference
66 -- -- Not Used
67 GRY 2701 5 Volt Reference
68 -- -- Not Used
69 DK GRN 676 HO2S Heater Low Control Sensor 1
70 BLK/WHT 1423 HO2S Heater Low Control
71 LT BLU/BLK 844 Fuel Injector 4 Control
72 PNK/BLK 1746 Fuel Injector 3 Control
73 BLK/WHT 451 Ground
Wednesday, August 31, 2005 5:04 PM
Alright, thanks for the schematic. One more question... What do I do with the resistor on the Eco or will I need it?
Monday, October 03, 2005 7:01 AM
Did you ever solve this?
Monday, October 03, 2005 7:02 AM
Also i heard something about a diode instead of
a resistor working better is that right?
I lost the link to the thread that said anything about
it.
