Sealing Fuel Rail Tap? - Boost Forum
Monday, September 12, 2005 9:47 PM
I have tried everything except tig welding to seal the gauge into the rail, i keep leaking alittle bit of fuel, anyone have any suggestions
<a href="www.daptronics.com">www.daptronics.com Huge Discounts on Electronics</a>
Re: Sealing Fuel Rail Tap?
Monday, September 12, 2005 9:51 PM
RTV sealant possibly?
Monday, September 12, 2005 10:45 PM
JB weld is very good for all sorts of things...including sealing leaks. try it, its good stuff. make sure that you apply it around the entire tap where the gauge is, not just the spot that leaks, and that there arent any air bubbles in it. and also make sure you mix the same amount of both parts and mix it well before applying.
_________________________________________
450WHP Turbo Ecotec swap in the works...
Tuesday, September 13, 2005 7:38 AM
I had the same exact problem. Only mine did seal at first but the guage didn't work. So I had to take it out and replace it, and when I did I couldn't get the new one to seal for nothin. So what I ended up doing was putting a pipe plug in the rail (that sealed luckily) and moving my guage to the line before to the rail. I just cut the line then used f.i. hose and some hose barbs to connect it. No leaks now.
"Spent way too much to give up now!!!"
Tuesday, September 13, 2005 8:48 AM
teflon tape
Tuesday, September 13, 2005 1:05 PM
what happens if that teflon tape bustes off and gets into what you are trying to seal?
i been using teflon paste "with teflon" for years with great luck from oil stuff, to gas stuff , to my water/meth injection set up with no issues.
Tuesday, September 13, 2005 1:25 PM
teflon tape if theres no chance a small piece coming off will hurt or block up anything
teflon paste if its something that a small piece of tape could clog
thats how i was taught
5K PB: 24:50
10K PB: 54:26
Tuesday, September 13, 2005 1:55 PM
the paste works as well
ive never had any problems with the tape , but i guess i shoulda said to keep the teflon tape on the higher threads , to help prevent it from getting inside and clogging something
Tuesday, September 13, 2005 2:51 PM
Loctite 567 will work we use it at work on high pressure fittings ok with gas oil diesel anti freeze etc.Apply it to the threads snug things up and your good to go.
Thats Him Officer The WICKED One.
