I just talked to JBP about finishing up my new port and polished head.... 1mm oversizing on the intake..... and a forced induction P&P....
So now that the weakest part of my car will be fixed..... I'm going to want to turn up the boost......... How MUCH psi can a Bottom end handle.... it was taken care of immaculately...
Bone stock bottom end..... I want to run it for 1 summer with the built head installed on a little higher boost then I currently run daily..... which is 8.7 psi................
So I can save up for a Fully built bottom......
Thanks
JDM Civic Hatch
Nobody can answer this for you.
Keep pushing it until it goes, and then let us know.
All failures on this message board were caused by poor tuning.
Also, why would you call the head the 'weakest' point? Maybe 'most restrictive', but weakest' is far-fetched...
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
That depends on your tuning abilities. The block is durable, sleeves are thick, pretty low compression. It could take 10 psi on a good tune with proper fuel mods. However... just spend the extra $700 for forged rods and pistons.
Spotabee Racing wrote:However... just spend the extra $700 for forged rods and pistons.
It takes more one $700 to build the bottem end. You also have to consider boring & honing the clyinders, piston rings, cam bearings, rod bearings, main bearings, turning the crank if needed, balancing the crank, oil, coolant, headstuds, sealants, ALL of the gaskets, lifters, timing chain, timing sprockets, pushrods, water pump, oil pump, oil pump shaft, oil pump screen, assembly lube, freeze plugs, assembly of the short block, etc....
Yea, its alot of sh*t
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
-1996 2.4 liter + Turbo + Built motor + Torco + More boost = Lots o' Power
-2000 Mustang GT + 2004 Cobra motor, Whipple 2.3 supercharger,
built rear-end,Dodge Viper spec T56 6 speed, bolt-ons = wheelies at the track!!!!!
it is a lot. but for someone who wants to run just enough boost that forged internals are necessary but not go crazy overboard on it (which personally i like to go crazy)...
I would say that if yor running an intercooler, and have a proper tuen using a wideband O2 then 10-12 PSi should be ok, as long as you keep the oil changed and and what not.
Tuning is the key, and an A/F guage wont do the trick, a wideband is almost mandatory, it willbe the best 350 bucks you spend.
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
That pretty much says it all.
Support the site that supports your habit, Go Premium.
HotRodV6 wrote:I would say that if yor running an intercooler, and have a proper tuen using a wideband O2 then 10-12 PSi should be ok, as long as you keep the oil changed and and what not.
there's no almost to a wideband with stock bottom end lol. it's a MUST if you want to save your motor.
i have ben running 10 lbs for about a year know no problems.
You have bass I have
sweet 10 psi ????
My has hit 10 psi but I didn't know if it was safe so I readjusted my waste gate.....
I will probably run 12 psi......... thanks guys !!!
JDM Civic Hatch
