hey guys can i use ford brown top 35lb fuel injectors in the 2.4l motor . i know that they are low impedence and i just want to know if they will fit right and to see if anyone has already been using them and how well they work thanks.
Matt Macomber wrote:hey guys can i use ford brown top 35lb fuel injectors in the 2.4l motor . i know that they are low impedence and i just want to know if they will fit right and to see if anyone has already been using them and how well they work thanks.
as long as you have a way to tune them go for it.
thanks guys i just wanted to use them for my turbo setup , sometimes its hard to get someone to respond in here .
what are you going to use for tuning? SAFC? HP Tuners? E-manage? Megasquirt? What?
i have an safc II that im going to use for the tuning , i just wanted to make sure that they will fit and hook up alright
thanks for the help
Matt Macomber wrote:i have an safc II that im going to use for the tuning , i just wanted to make sure that they will fit and hook up alright
thanks for the help
it's going to be hard to tune the right fuel curves unless you have a compressor map of your turbo to help you. have fun with that.
well i have the safc 2 and a wideband and together with those two i should be ok . also there is a dyno shop around where i live, if i cant get it right ill just let them tune it so hopefully that will work
Will the factory injector clips work with the browntop injectors?
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
indeed they will
Whats the CC size of that injector and out of what cars did they come from?
Thanx Charles
i got a better idea. you tell me how much power you want to make and i'll tell you what injectors to get.
they come out of a 86-88 ford turbo coupe 2.3l and they are 35lb and 360 cc.
