High mileage turbo cars. Are you driving one? - Boost Forum
Saturday, August 27, 2005 4:20 PM
Curious to see who's turbo Cavalier has the highest mileage on there engine.
List the following:
What engine you have.
At what mileage you boosted your car
How many current miles are on your car
Is your engine stock, rebuilt, or beefed up
What aftermarket engine internals your running
Any engine problems you may have run into along the way or are currently experiencing (Knocking, burnt valves, spun bearings, chucked rods, etc. etc. etc.)
Re: High mileage turbo cars. Are you driving one?
Saturday, August 27, 2005 10:41 PM
I'm sure I don't have the highest miles, but here ya' go anyway...
3.1 V6
approx. 107k
bad speedo, but about 118k
rebuilt / mostly stock
What aftermarket engine internals you're running
mild Crower cam & Crower lifters
Any engine problems you may have run into along the way or are currently experiencing.
no current mechanical issues
only previous engine problem was a vacuum leak from a poorly sealed upper intake gasket
Have you seen the turbo wagon?
14.069 @ 98.91mph
229.1hp & 261.7ft/lbs @ 6psi
no tuning time
Sunday, August 28, 2005 7:23 AM
i got 144k on the car/ stock tranny and 22k on the motor( put in a 12k miled 2k 2.4l).
problems- none.
Sunday, August 28, 2005 7:41 PM
List the following:
Does a Sunbird count?
2.0 OHC
0 miles, factory turbo
227,177
stock
none
Once upon a time it recieved a head gasket. Water pump wore out around 220k. No current issues.
If limited to Cavaliers, then
2.2 OHV
boosted around 240k miles
270,080 current
stock engine
no aftermarket internals
Past problems: head gasket leaking externally (infamous on 2.2's).
Damaged (and replaced) rod brgs winter 04/05 due to my adding too much timing.
Ongoing problems: compression on cyl 3 slightly down since used engine was purchased 8/03.
-->Slow
