I will be running a t3 turbo in a litte project I like to call longswords man
. i've seen some pics of turbo setups. they have 1 maybe 2 exrtra injectors on the intake
and I was wordering how those work and in my case will i need this. I plan to run about 6-10 lbs of boost and want to see about 250-275 horses a on a turbo built motor of the 2.4
if not can some one recomend a fuel setup that is not costly
Some people go with EIC's (extra injector controllers) but mainly just the 95-97 2.2 guys that cant upgrade their injectors. Since you have a 2.4 you can just get larger injcectors and even a emanage if you want.
<a href="http://www.cardomain.com/ride/448390"><img src="http://www.clubcav.com/gallery/albums/userpics/10271/sig7.5.jpg">
any injector recomedations?
simply if you plan on running 10 psi on your 2.4 sweet....... get 35 lb and up injectors and you'll have plenty of fuel then get a FMU preferrably Cartech adjustable ...... not pricy and works well...... if you have any cash left over then get a SAFC-2.............
you NEED the FMU and the injectors !!!!! just to MAKE sure your car doesn't lean out.....
bad news if it does !!!!
btw..... an FMU will definitely need a good dyno tune .....................
good luck !!!!
JDM Civic Hatch
where could I find an injector swap for the 35 lbs injectors or what would best fit my setup ?
well a nice set of RC engineering ones would work well............ for 10 psi .......... 38 lbs injecotrs would do........... or some ford ones......... red tops are #30...... etc...... you need to find which color goes with the amount of fuel you need to add...............
JDM Civic Hatch
