almost done purchasing parts need help - Boost Forum
Saturday, August 13, 2005 9:33 AM
This is for a 98 2200
OK right now I have
Turbo w/ internal gate
Manifold
bov w/ flange
30 lb ford red tops
In the mail.
Intercooler
Charge Piping
Waiting for more money
Gaskets,
Oil Lines,
Megasquirt
My question is right now I only want to run 5-6 psi on this small 42/48 turbo? will i need a higher fuel pump right now, or can i wait until i want to run more boost?? Also will I need an Adjustable Fuel pressure regulator? I am not running a FMU, I do not like them and thats why i'm going Megasquirt
Re: almost done purchasing parts need help
Saturday, August 13, 2005 3:17 PM
Well, since you're only running 5 psi and you said you've already got some injectors, it's not TOO serious to pick up the fuel pump or FMU. HOWEVER, this is something I'd highly, highly suggest doing just to be on the safe side...
I wouldn't wait too long without either of those, just to be SAFE. You don't wanna lean the motor out
MaximumBoost.net
1-888-TURBO-31
sales@maximumboost.net
TAX ID: 45-8013458577-3
Saturday, August 13, 2005 3:18 PM
Maybe pick up a wideband o2 and dynotune that puppy also so you can get it exact
MaximumBoost.net
1-888-TURBO-31
Saturday, August 13, 2005 6:51 PM
I'm not running an FMU at all. Megasquirt is for that why bother with something that is harder to tune and not exactly the safest way to run things
Will I need to AFPR to run the 30lb ford injectors at idle? has anyone had any problems with out one?
