2200 oil filler tube ? - Boost Forum
Thursday, August 04, 2005 8:59 PM
any one that has the log style manifold on there 2200. what did u do to get the fill tube out the way.
DRIVE HARD OR DONT DRIVE AT ALL!!!
Re: 2200 oil filler tube ?
Thursday, August 04, 2005 9:12 PM
Your gonna have to section it its very easy if you have acess to a welder. just make sure you measure exactly how much you section it so you can do the same to your actual dipstick.
Friday, August 05, 2005 7:34 AM
yea thats what i was thinking just wasnt sure what everyone else did, thanx
Saturday, August 06, 2005 10:53 AM
I took the hard road.
Cut and capped the top just below the section the cap sits in. Bought a cheap dipstick off of ebay (was off of some ford). bent it to fit and wielded into lower portion of original fill/check tube. Turbo oil return is mounted 2" above that.
Took the valve cover off & cut a hole in the back right. Had the top of the old fill/check tube weilded on & pulled the old dipstick out of the cap.
Really doesn't look bad, but time consuming.
Sunday, August 07, 2005 4:15 PM
they sell relocator oil fill tubes at j tuners.com
slide or die
Sunday, August 07, 2005 7:01 PM
it doesnt relocate it, it just adds a return fitting for the turbo
