MAP sensor questions - Boost Forum
Sunday, July 24, 2005 8:36 PM
does anyone on here with a the 2.2 ohv boosted know how to get around the crappy 1 bar map sensor in these cars? I've read about people using check valves but only on the 2.4s so i was curious. I know the 2 bar maps out of the late 80's pontiac sunbird turbos work but i am looking for something to modify my stock one...any ideas would be awesome. Thanks
Re: MAP sensor questions
Sunday, July 24, 2005 8:44 PM
ya the check valves work for the 2.2 ohv to. works quite well.
Sunday, July 24, 2005 9:12 PM
My 2200 has been turboed since July 2004 without a map sensor, and I havent noticed any problems.
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
-1996 2.4 liter + Turbo + Built motor + Torco + More boost = Lots o' Power
-2000 Mustang GT + 2004 Cobra motor, Whipple 2.3 supercharger,
built rear-end,Dodge Viper spec T56 6 speed, bolt-ons = wheelies at the track!!!!!
Sunday, July 24, 2005 9:23 PM
you're not using the map the sensor at all. or just not using a check valve
Sunday, July 24, 2005 9:30 PM
Oops, I meant that I am not using a map sensor. I doubt the car would even run without the map sensor, I already tried.
13.2 @ 108 mph
Ok, hold on...i gotta start re-reading my post. I am not using a CHECK VALVE.
13.2 @ 108 mph
Sunday, July 24, 2005 9:34 PM
That's what i figured you meant. I'm not running any sort of check valve either. I run 15 lbs. of boost, a little nitrous, e-manage, and run pig rich at idle. And i don't have any problems at all, not even a check engine light.
Sunday, July 24, 2005 10:22 PM
i have a ? im bout to turbo my 2200. with a t3 turbo wastegate and blowoff valve low boost. is there ne thing else i would need like this map sensor. im a little lost.
DRIVE HARD OR DONT DRIVE AT ALL!!!
Monday, July 25, 2005 7:45 AM
Thanks for all the help, i just wasn't sure about the check valves because of the way the map sensor plugs right into the intake manifold on the 2.2. Do i have to tap the hole and put a fitting in or is there an easier way? I've never really looked into this but for some reason i'm still throwing a code and that's the only thing i can see doing it.
