I am seriously tossing around the idea of a low boost non intercooled turbo kit for my 03 base coupe.
I figure 4 psi or so.
Things I woud need:
turbo
turbo manifold
oil lines
charge pipe
assorted fittings and hoses
What for fuel? If I am running low boost like that. Would I be ok with a simple FMU?
Help me out org!
2006 Cobalt SS I/H/E ZZP S2 HPT 2.8/60's Etc...13.8@105(I need to learn how to launch)
Don't forget gaskets, and if the turbo is water-cooled, you'll need some water lines.
You'll be okay with an FMU at 4psi. Just remeber, you're going to want to TURN UP THE BOOST!!!
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
can I ask why not just go intercoolered? its like 300 or less for a decent on and its better for the engine. also you forgot wasategate and blowoff vavle.
Kick azz is my boost hero!!! "
Internal WG. And yeah some BOV, thanks!
I would sugest to get a intercooler even if it is a small one. even at 4 psi you will be giving your car way more heat than it needs
go to johnyracecar.com or speedpartsrus.com
they have cheap intercoolers
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
