help.... just installed hahn kit and no start?? - Boost Forum
Saturday, July 02, 2005 6:12 PM
I just finished installing my hahn kit. When I turn the key to ACC position, I can hear the fuel pump run for a second and there's about 22psi in the lines according to gauge. When I try to start up, the engine cranks, and the fuel pressure goes ways up, but the engine won't catch. Any suggestions?
I was thinking it might be the injectors.. does the order of the two wires going to each injector matter? How could i check if fuel is reaching the cylinders? Any other things that might be stopping me from starting?
Re: help.... just installed hahn kit and no start??
Saturday, July 02, 2005 6:15 PM
The little things get you, make sure everything is plugged back in, like the coil wire harness, vac lines, etc.
Sunday, July 03, 2005 2:22 PM
check your coils, vac lines, and maybe you are making too much fuel pressure for startup.
