If you could build your *DREAM* motor...how? - Boost Forum
Thursday, June 30, 2005 8:23 PM
I'm picturing a 2.3HO (same as W41 with less wild cams)
9.5:1 Wiseco's
Eagle H beams
Lightened and balanced crank
bored block .020 over
MLS head gasket
086 head, ported on the exhaust side, polished up, 5 angle job
Stainless valves
(not sure what's involved, but make the drivetrain suitable for 8k rpms)
Then its time for boost...
something along the lines of .70 trim
intercooled
tuned for 20-25 psi
I don't care if you got a stock bodied J, or something set up like karo's car...that's going to go insanely fast
The only thing that I could think of that might top it...involves a boosted 3.8 lol
Re: If you could build your *DREAM* motor...how?
Thursday, June 30, 2005 8:28 PM
are we talking just for j's?????
"Official Jewish J-Body"
Thursday, June 30, 2005 8:29 PM
you almost described my motor lol
Thursday, June 30, 2005 8:45 PM
3 Angle valve grind
Titianium Valves
Titanium valve spring retainers
Double rate valve springs
Polished combustion chambers, matched to overbored block
Highly polished exhaust ports
Mild polished intake ports
HO Cams, intake modified for cam pickup and steering hex drive
Cryo-treated lifters
Adjustable cam gears
9.5:1 CR .20 Overbored Wiseco Pistons
Eagle H-Beam Forged Rods
ARP Head Studs
Victor Rienz head gasket
Upgraded rod and main bearings
Knife-edged and cryo'd crank
2.3 Oil Pump Swap, high volume
Balance shaft delete
Full Balance and Blueprint
HO Intake manifold, port matched to head, TB opening port matched to 65mm TB
65mm TB
2.5" Full Charge piping, routed under engine, powder coated black
6" Intercooler
Garret GT35 .72 A/R ceramic ball bearing turbo
Equal length tubular header, stainless steel
40mm Wastegate, vented to atmosphere
2 Turbo XS RFL BOV's
Electronic multi-stage boost controller, RPM dependant
CD High voltage multiple spark ignition system, converted to wire-on-plug
High flow in-tank fuel pump + external high flow fuel pump
3" downpipe
3" Turbo-Back exhaust, no cat, dual mufflers with electric cutout
770cc Injectors
Electromotive Tec-3 Engine management
Manual transmission with limited slip diff, cryotreated and upgraded
Stage IV Spec Clutch (Stock flywheel)
There's more I can't think of right now... but thats a start
Thursday, June 30, 2005 8:56 PM
ok well if it is for a j all i can say is the upgrades you all are gonna list but it would def. have to be a root supercharger..........not if it didn't have to be a j then my car would be n/a.....nothing like raw unassisted power...
Thursday, June 30, 2005 9:00 PM
Machzel08 wrote:ok well if it is for a j all i can say is the upgrades you all are gonna list but it would def. have to be a root supercharger..........not if it didn't have to be a j then my car would be n/a.....nothing like raw unassisted power...
there's also nothing like feelin a turbo spooling, and leaving the NA guy in the dust
Thursday, June 30, 2005 9:02 PM
I would probably just pay Karo to build it and install it. He seems to know what he is doing.
Thursday, June 30, 2005 9:25 PM
I dont have a dream engine, but if I had a choice, I'd make my lil OHV as boost hungry as possible. Make the best with what you've got.
I believe im on my way to that, but I couldn't possibly list everything I want to do.
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/stevefiresig.jpg"></a>
Thursday, June 30, 2005 9:30 PM
titus03 wrote:I would probably just pay Karo to build it and install it. He seems to know what he is doing.
Todd Miller built Karo's motor
Thursday, June 30, 2005 10:40 PM
I'd trade in the built LD9 for a built Ecotec, no offense but the Ecotec is so technologically advanced compared to the LD9.
It would be similar comparing an LS2 to the LT1.
You can do all you want to the LD9 but if the guy in the next lane has equally built his Ecotec along with that LD9, my money is on the Ecotec.
Thursday, June 30, 2005 11:21 PM
gmfreak wrote:I'd trade in the built LD9 for a built Ecotec, no offense but the Ecotec is so technologically advanced compared to the LD9.
Why did you have to say that? Here we go again. Onto round 32 and the ecotecs come out swingin!!!
z24 aint afraid of no ecotec
Friday, July 01, 2005 1:09 AM
GM V-6 with a built motor, dry sump oil, cam, badass headwork, bigass rockers, Motec M4 ecu, 10 gallon fuel cell, Aeromotive A1000 fuel pump, and a big ol' turbo.....all in my Sunfire.
Screw building a 4 cyl..
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
-1996 2.4 liter + Turbo + Built motor + Torco + More boost = Lots o' Power
-2000 Mustang GT + 2004 Cobra motor, Whipple 2.3 supercharger,
built rear-end,Dodge Viper spec T56 6 speed, bolt-ons = wheelies at the track!!!!!
Friday, July 01, 2005 4:41 AM
DropTopPaul wrote:I'm picturing a 2.3HO (same as W41 with less wild cams)
9.5:1 Wiseco's
Eagle H beams
MLS head gasket
Stainless valves
intercooled
tuned for 20-25 psi
I would go with this set-up but high compression, with standalone and dyno tuning it would be evil!!
Friday, July 01, 2005 4:45 AM
Thats what I'm saying.
The thing that gets me is no one ever put the time into the LD9 as GM did the Ecotec. If GM had did with the LD9 as they did with the ecotec I''m sure the same can be done.
To me it seems that just now people are really starting to really tweak the LD9's and we will see a lot more out of them. It is all in tuning and set-up. We have seen soem stock LD9's go 12's with a turbo set-up, as well as some stock ecotec's, truley no one has the edge yet. That is my 2 pennies
Friday, July 01, 2005 5:00 AM
I'd throw in NOT a hampster........but a guinea pig.
Friday, July 01, 2005 7:00 AM
Mr. Pute wrote:I'd throw in NOT a hampster........but a guinea pig.
Why not go all out and upgrade to a large rat. They move pretty fast.
I'd like to get the Mantapart 2.5 S/C for my car. Maybe in the future if they would talk to me.
Friday, July 01, 2005 7:14 AM
Hmmm........dream motor
Stroked LD9 with no balance shafts
HPC coated 9:1 pistons
HPC coated rod and main bearings
Eagle Rods
ARP bolts and studs
2.3 flywheel
Cometic MLS HG
HO Cams
JMTS cylinder head
Then throw a turbo kit and engine management on it
Jason
99 Z24
#25 to register on the Org !!
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
Friday, July 01, 2005 8:17 AM
I think a turbo LGO might have somethin nasty for those ub3r eco guys. Yes, IMO the eco motor is stronger out of the box....is it worth debating over? not really. Technically...LD9 still holds record for hp, no one has topped 410whp set by mike karas. In all honesty, it would be tough for the LGO to top that, and IMO that's a stronger motor then the LD9. But now we're just talkin opinions, so it don't really matter. All 3 4cyl motors for the J can be powerhouses. Like I said, the only thing that really could top it, is what adler said. A boosted V6 perhaps
Friday, July 01, 2005 9:02 AM
my pigmy pig trumps that
Friday, July 01, 2005 9:07 AM
The motor of mine that's sitting in DC
@!#$in comp cams
Friday, July 01, 2005 10:04 AM
I`m building mine this winter
Friday, July 01, 2005 1:30 PM
mmmm... built 2.0L eco turbo.
My Car
Friday, July 01, 2005 2:31 PM
a month ago it would have been what i was close to having..
Built 2.3 HO
-forged crank, rods, pistons
-ported 086 head
-top end work for high RPMs
-NVG-T550 + torsen
-custom tuned stock ECU
then boosted to high ^$%#
i too like the LGO over the LD9. way more HP stock, less BS to deal with (oil system, cam sensor, balance shafts) and the same bellhousing. im sold. now i think if get another J sooner or later i will swap in a 2.0 eco since its basically a decent build from the factory.
Friday, July 01, 2005 4:04 PM
The Ho will start to have problem at 8k so you better build it for 9500rpm
As for the crank, Gmpartsdirect still have some kellog crank for the 2.3.
I'll be using 2.4 rods in my 2.3 so my C/R will go down to 7.56:1. I have a T3/T04E with .48 turbine and .70 compressor so I can push alot of air.
So I'll have a reliable engine but weak axle. I hope to see some # by the end of the summer.
Gilles
2.3 Ho
Friday, July 01, 2005 4:56 PM
L67 3800 V6 of course.
Precision Turbo PT70GTQ compressor
Precision Turbo custom intercooler
Modified LS1 throttle body
Wilson Manifolds-modified L67 lower intake/plenum
INTENSE™ Stage 4 cylinder heads
Cometic .052" 4-layer MLS head gaskets
INTENSE™ 8.0:1 race short block
ATI SFI-approved damper
Rollmaster double roller timing chain setup
INTENSE™ Stage 4 turbo cam
CompCams 'OE R Series' lifters
INTENSE™ oil-restricted pushrods
INTENSE™ 1.70:1 full roller rocker arms
Weldon 2015 fuel pump
PRJ custom fuel logs
Siemens 60.0 pound/hour fuel injectors
B & R Racing custom headers with ceramic coating by Toefco (1 5/8" primaries, 2 1/8" secondaries, 2 3/4" y-pipe, 3" downpipe)
Meziere electric water pump
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
