please help.. what kind of fmu should I get? - Boost Forum
Monday, June 13, 2005 10:34 AM
ok if you seen my dyno results I know that I need a fmu really bad.. I would like to know most of your setups and how you did it and your opinion on what I should do,. any way I did a dyno and I'm running way way lean to be exat 16:1 and 18:1 when I should be in the 12:1 ratio. I've been looking on what kind of fmu to get and they actually very from ratio's. what type/kind should I get?? I don't really want to run the car until I get one due to early detonatin. and if I get a fmu do I really need to get a fuel pump? right now I'm running on 3psi which added crap to the wheels until I get this fmu. all I want to see is about 7psi maybe 8 at most. thanks in advance.
**changes are here**
Re: please help.. what kind of fmu should I get?
Monday, June 13, 2005 11:19 AM
Vortec 12:1 FMU is good. Don't forget to buy a SAFC-2 to help you tune it.
You'll be able to run 8 psi no problem.
Monday, June 13, 2005 3:11 PM
Sasuke wrote:Vortec 12:1 FMU is good. Don't forget to buy a SAFC-2 to help you tune it.
"SAFC-2"???? what about fuel pump is that neccessary?
Monday, June 13, 2005 3:20 PM
DO NOT BUY A 12:1 FMU.
Thats way to freaking big. Buy an adjustable FMU so you can adjust the ratio to what the car needs, instead of making disc guesses and clipping injectors trying to run too much fuel pressure, or flooding it out and wondering why its so rich.
Monday, June 13, 2005 3:40 PM
I have the begi/cartect fmu and have no complaints.
Monday, June 13, 2005 4:00 PM
Not to sound stupid but summet doesn't look like they have a adjustable fmu.. where do you pick one up at?.. and when I get this adjustable fmu do I need a fuel pump or should I be fine with what I have, remember all I want to run is about 7-8 psi
Monday, June 13, 2005 4:02 PM
Vortech has one, and Cartech has the Begi 2025. The stock fuel pump is only good to about 70-75psi for short periods of time. A replacement Walbro 255 is only like $100. I really can't say what you need if I don't have more information, like what hp you expect to be making.
Monday, June 13, 2005 4:18 PM
awesome thanks
Monday, June 13, 2005 4:28 PM
FstCavZ24 (Turbo ECO) wrote:I have the begi/cartect fmu and have no complaints.
where did you order yours from?
Monday, June 13, 2005 4:37 PM
I got mine through HAHN along with some other fuel stuff. I recommend just using yahoo or google to find the best price. Seems like about $190 is the cheapest but i don't remember where.
Tuesday, June 14, 2005 2:38 AM
I'll sell you mine if you want.
E-mail me at jburic@tampabay.rr.com
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's ----12's ----11's ----10's
Tuesday, June 14, 2005 8:18 AM
12:1 is too big? I'm going to run about 10psi with a walbro 255 fuel pump upgrade. Any other suggestions, or am I in the right ballpark? I have a ecotec.
Tuesday, June 14, 2005 8:20 AM
40 WOT base pressure + 10 psi * 12:1 = 160 PSI of fuel pressure. The pump obviously can't support that, but its way too much.
Wednesday, June 15, 2005 6:13 AM
Oh yeah, I was told that I can adjust the 12:1 FMU. I guess I'll find out.
Wednesday, June 15, 2005 5:44 PM
yeah, a 6:1 should be enough for 10 psi of boost with the walbro, but don't forget to upgrade the injectors too, they do a good job on supplying enough fuel so you get the max power from the turbo.
