I dont know why but saturday just wasnt my day. I think it was the blistering heat.
First run 14.99 (ouch), second run 15.15 (OUCH!!!!) And my 3rd run happened as the air was starting to cool, and my s/c had time to cool for about an hour, i ran a 14.8.
Yea i was an idiot and ran cam 2 (110 octane leaded) My cat is hollowed out so i figured i would try it. I think the cam 2 killed my top end.
Ok, so when i ran a 14.6 i hit 95mph with a 60 foot of 2.19
On sat i was hitting 60 foot's of 2.10! But i could only get 92mph!!!!
Im like, with that king of 60 foot i should be running low 14s if i could get my trap speed back.
This is also with smaller than stock AO32R tires.
Next time im going to try running on my 225/45/17's for the first time, and run 93 octane gas.
I was pissed.
-Ben
<img src="http://memimage.cardomain.net/member_images/3/web/831000-831999/831395_11_full.jpg">
not bad the one time i attempted to run mine a few days after getting the kit I could only trap 87 which due to the weather/inexperience/no traction/wrong tires/not broke in/too lean all contributed towards that im sure, i wont run again till i have the right tires and fuel setup
![](http://registry.gmenthusiast.com/images/matt38y3/sig.jpg)
Ben Brown wrote:Yea i was an idiot and ran cam 2 (110 octane leaded) My cat is hollowed out so i figured i would try it. I think the cam 2 killed my top end.
Possibly killed your 02 sensor.
Some more proof that higher ocatane doesn't help. unless tuned for the higher octane.
My Car
yeah leaded gas kills the o2 sensros
those times arent to bad , it will take some practice
Remember, this is an Ecotec not a 2.4... The 2.4 rsm kits are running high 13's, i think im the first one with the Eco RSM kit to post track times.
-Ben
Ben Brown wrote:Remember, this is an Ecotec not a 2.4... The 2.4 rsm kits are running high 13's, i think im the first one with the Eco RSM kit to post track times.
-Ben
Nothing against anyone..... but who with a RSM SC Kit on a 2.4 is running high 13s just with the SC Kit? Unless you mean a modded 2.4 with the Stage 2 Kit....
I like my 14.6@101.5 HAHA one of these days I'll learn how to launch.
there is other J's besides whats on this board running the kits
heh im too lazy to check other boards lol. But that one guy i dont know the name though, 13.99 Im sure its not JUST the rsm kit, but its a rsm kit in the 13's non the less.
so much for the 65hp claimed by them... every jbody with the RSM kit i have seen run the 1/4mile with, run the same times at the GM s/c cars... and the RSM kits on the 2.2L were running slower times then the 2.4L's with gm's kit. 13.9 is believable with the rsm kit but not on a stock motor.
Supercharged 2.4L
Im about to have a guy i know hack off that EGR and order a bigger drive pully lol. Im sure the 10psi pulley would set me well into the 13's
you will need to get bigger injectors if your doing that im maxing out my stock ones right now at 5psi
Im thinking a new fuel pump and hook up that FMU that comes with the kit (of corse when i do that ill put in an adjustable FPR too. Right now my a/f is in the 12's so im really not having any fuel issues... im sure an extra 5-6 psi would cause problems but hopefully with a fuel pump/fmu/reg i will be able to keep the stock injectors.
