Trying to get my boost gauge to work here.
I bought some rubber adapters and t fittings. The way i have it hooked up is a rubber adapter on the FPR then a t fitting on that and the FPR tube connected to that t fitting. Then the nylon tube with a rubber adapter on it hooked to the t fitting and ran to the gauge.
I started the car up without the gauge hooked up and could feel a vacume coming from the nylon tube so i figured cool.
Hooked the gauge up, went out for a drive and nothing. Took the car up to 5k rpm still nothing. So whats the deal?
you should get a signal off the IM or charge pipe right before the TB
I think with all those interconnections it might be interfering
LE61T PTE6262 Powered
Make sure the nylon tube is not crushed or collapsed along it,s length or at the gauge.
![](http://img213.imageshack.us/img213/9692/ipook6.th.jpg)
Thats Him Officer The WICKED One.
This was the reason.
Rigged it all up with washer fluid/vacuume tubing and a t fitting and it works perfectly now.
Hopped on the highway and saw 6psi.
