MSD - Boost Forum
MSD
Tuesday, June 07, 2005 7:22 PM
wat can i use in my 99 Z turbo for timing? does MSD ignition work for us and is that timing? im running 9psi out of a T3 with 330ccinjectors, AFPR, FMU, Safc-2. or do i not need anything for timing? thanx
speed kills, drive slow, drive a honda
You are what you Drive!
Re: MSD
Tuesday, June 07, 2005 7:25 PM
Whether or not you need timing depends on if you are getting knock or not. If you aren't getting knock, then you might be ok. You might want to think about a stronger spark though through upgraded coils.
Re: MSD
Tuesday, June 07, 2005 7:29 PM
closer gapped plugs? and coil then? can i do MSD does that do anything or just a coil and where can i find this coil
Re: MSD
Tuesday, June 07, 2005 7:33 PM
Msd dis-2 works well for our cars. I would reccomend pulling a few degrees at the higher rpm's even if your not knocking. Rather safe than sorry.
1998 Cavalier Z24
Re: MSD
Tuesday, June 07, 2005 8:43 PM
dis 2 with coil packs works really good on 2.4's. Im sellin it if you are interested.
Re: MSD
Wednesday, June 08, 2005 3:35 AM
your selling what dis 2 with coil packs? for how much
Re: MSD
Wednesday, June 08, 2005 12:48 PM
should be the 8224s...
Re: MSD
Sunday, June 12, 2005 7:51 AM
Shifted wrote:Whether or not you need timing depends on if you are getting knock or not. If you aren't getting knock, then you might be ok. You might want to think about a stronger spark though through upgraded coils.
question of the day wehre can i find stronger coils for a 99 Z? of a good quality too.
Re: MSD
Sunday, June 12, 2005 5:59 PM
^^^ Read above msd 8224 coils
Re: MSD
Monday, June 13, 2005 3:31 AM
oh wasnt even paying attention to that thanx...
