to those with superchargers - Boost Forum
Saturday, June 04, 2005 9:46 AM
What gauges do you guys add? I plan to get the eco supercharger from GM and was looking into a gauge setup. A boost gauge is a must, but what other gauges are typically used. I am planning right now on a two gauge pod, so it looks like I only can go with one more gauge. Right now I'm thinking either oil temp or egt gauge.
"If you aren't shifting, then you certainly aren't driving!"
Re: to those with superchargers
Saturday, June 04, 2005 10:09 AM
autometer sport compact gauges and the lotek triple pillar.
definitely go with wide band o2 or egt if you plan on adding any performance mods other than the s/c
14.82 @ 97 mph
Saturday, June 04, 2005 11:52 AM
well it really depends on how far you want to take your mods after the supercharger. I have a boost gauge and A/F ratio gauge. That is prolly all i will need because i dont plan on adding much more boost to it. I also dont need to tune my car because of the reflash, so i think a wideband is kinda an overkill. If your gonna stick modest with your mods, and af gauge should be fine, if you plan on going pretty extreme with your mods, and wideband is a must. You also dont really need a boost gauge, thats more for looks. You will already know how much PSI you will be pushing with the stock pulley, so unless your planning on upping the boost, a boost gauge really isnt needed, its more for looks.
2006 Black Cobalt SS Supercharged G85
13.91@102.77
Saturday, June 04, 2005 1:51 PM
id say a wideband 02, EGT, and oil pressure
Saturday, June 04, 2005 3:53 PM
ill sell ya my lotek 3 gauge pod.. $45 shipped. brand new in the box.. email me if ur interested.. xcavix@hotmail.com
www.OverloadCars.net
Saturday, June 04, 2005 7:00 PM
I have a boost gauge and a plx wideband.An air/fuel gauge is useless.All it does is put on a light show at night.I think a boost gauge is a must.You might know how much boost the stock pulley is supposed to make,but you wanna make sure you are actually making that much boost.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
Sunday, June 05, 2005 3:15 AM
I went with the Lotek 3 pod pillar and got Boost (30 vac 20psi), Oil pressure and Knock
my oil pressure and boost gauge were from Stewart Warner, and i highly recommend these gauges over Auto meter..
Sunday, June 05, 2005 9:05 AM
af ratio gauge is useless to tunning. You cant tune on an AF ratio gauge, but it does work well to monitor your car under WOT. Just to make sure your not running lean.
13.91@102.77
Sunday, June 05, 2005 4:17 PM
i just got a boost gauge.
Sunday, June 05, 2005 7:12 PM
Autometer phantom Oil pressure- Vac/boost- AFR. Lotek 3 gauge pod.
Thats Him Officer The WICKED One.
Monday, June 06, 2005 5:48 AM
None. I have no idea what my car is doing.
Monday, June 06, 2005 3:42 PM
Well if you did go with an EGT, how do we know what temp is bad for our cars? Wouldn't you need to find a gauge that shows the correct temps to be effective? Also, where did you guys put the boost/vac probe? I would assume on a vaccuum line, is this correct?
Monday, June 06, 2005 9:16 PM
probe? there isnt a probe, you just connect a tube going from the gauge into a vacumm line.
13.91@102.77
Monday, June 06, 2005 9:19 PM
wideband 02, EGT, vaccum/boost guage
