well 2200 rsm kit pretty much finished - Boost Forum
Monday, May 23, 2005 7:17 AM
so i bought the rsm 2200 supercharger off ebay i put it in got all i needed done now here are a few pointers to you guys
first off i had the 4 into one pacesetter header.... the pipe from cylinder two had to be dented a little for the shaft to fit
then the lower bracket had to have a notch grinded out of it and a couple of fins on the transmission had to be grinded off
the problem i have now is i think the supercharger needs an intercooler so first off to help the problem i am getting a cooltek oil cooler that i am going to attach right before the supercharger, also i am going to wrap my header to cool down my hood temps
the other problem is that if i leave the car in drive the shift from 1st to 2nd is very slow and painful so i have a b&m shift improver coing as well
anyone know where i can get an intercooler for this thing cause after like a run of two in a row the car loses alot of power
the other thing that totally sucks is the guy that sold me the kit didn't send me two of the bolts that connect the bottom of the shaft cover to the charger and the smaller bolts that clamp the the cover down. so that thing rattles like a mofo but it's all goodpeople pull up next to me like that thing is a peice of @!#$ and than that thing pulls past them =)
other than all that the car runs good. now i need to get that built short block from jbodyperformance.com and i am ready to go
2000 Dark metallica green cavalier. (2.2 2200) pace setter 4-1 header, magna flow high flow cat, dual quad tip dtm muffler, momo 16in rims, rk sport strut bar, rear vibrant strut bar, Floor bar stablizer, Crossdilled slotted roters with ceramic brake pads, 14lb.carbon fiber oem style hood, rsm lightened crank pulley, MSD Blaster2 Ignition coil packs, RSM Vortech Supercharger 8psi, 300cc venom injectors....
in another few months i will get the built short black from jbodyperformance.com
"Disarters are just another star falling in my yard."
Re: well 2200 rsm kit pretty much finished
Monday, May 23, 2005 8:21 AM
If you rap your header it will void the warrenty. Just thought you should know.
Hows the power on it? What rpm does it spool at?
Get dyno #'s asap!!!
Monday, May 23, 2005 8:27 AM
DO NOT WRAP the header , youll end up having to buy another 1 after it blows out
you might want to look at a few of the intercoolers that vortec sells from some of their kits , the might have 1 thats close enough for you to use
Monday, May 23, 2005 9:06 AM
read guys the warrentee is void i had to dent the pipe to fit the charger
it is a temp thing until i buy the rsm coated header
it starts creating boost very low in the rpm at about 3000 rpm its at 5psi and by the time i am near red line it is at 8-10 psi depending on how nice it is out
my estimate on the power i am prolly running a 15.5 cause i was racing the hemi 1500 2 door pick up and i was pretty much tied with him. and that is the quarter on that truck..... but i was tieing him while i auto sticked my car
2000 Dark metallica green cavalier. (2.2 2200) pace setter 4-1 header, magna flow high flow cat, dual quad tip dtm muffler, momo 16in rims, rk sport strut bar, rear vibrant strut bar, JDM Floor bar stablizer, Crossdilled slotted roters with ceramic brake pads, 14lb.carbon fiber oem style hood, rsm lightened crank pulley, MSD Blaster2 Ignition coil packs, RSM Vortech V-9 Supercharger 8psi, 270cc venom injectors, cooltek oil cooler, b&m shift improver.
Monday, May 23, 2005 6:44 PM
sinrocker wrote:first off i had the 4 into one pacesetter header.... the pipe from cylinder two had to be dented a little for the shaft to fit
I hate to say it but you installed your kit incorrectly.
Monday, May 23, 2005 10:19 PM
seriosuly though... I would deffinately not be happy with a 15.5 or anything around it with as much as that charger costs. A 2.4 swap and some bolt-ons or a cheap nitrrous set-up could have put you higher for less money.
Cardomain|Myspace
Tuesday, May 24, 2005 4:47 AM
i bought the charger used and there for cheaper
i did not install the kit incorrectly bobby from rsm said most of the 4-1 pacesetter headers will fit it but they are not built consistantly and some wont fit
so i hate to say it but you dont know what your talking about
the kit was installed the right way and fits perfect
Tuesday, May 24, 2005 7:45 AM
Lets see some pics man
Tuesday, May 24, 2005 8:44 AM
When you said you modified the lower bracket, I am assuming that you modified the charger bracket that bolts to the transmission. Also, you shouldn't have had to grind fins off the transmission.
Get a couple pics of the install.
Tuesday, May 24, 2005 11:37 AM
I think you'll do alittle better than a 15.5! 8-10psi up top! That's good for what 80hp!
I'm a basically stock 2200 with a few bolt-ons and without nitrous i hit a 15.7 lowest and 15.8s the rest of that night! So in all reality I only have about 125hp to the wheels if that much, and I got those times! You have atleast high 170s to mid 180s, which should be good for high 14s with an auto! I'd think atleast! Anybody correct if I'm wrong!
N2O + Bolt-ons = 220Hp/250Tq
Coming Soon:HpTunersPro, EagleConnectingRods, WiescoPistons, 13sec2200
Tuesday, May 24, 2005 12:43 PM
I hit a 15.5 when I was running 4psi on my turbo 2.2l. Of course it had an exhaust leak too and it was pretty hot outside if I rmember correctly. So running 8-10psi supercharged(less lag) you should run better than a 15.5. Probably closer to a 15.0 or better.
Tuesday, May 24, 2005 3:46 PM
Mike's engine pic:
Tuesday, May 24, 2005 8:16 PM
well the biggest problem is the shifting and of course the fact i need an intercooler
i am going to make a personal intercooler kit with tons of reinforced 3in hose and elbows and a junk yard intercooler
but if i leave it in drive it takes a second of two to change gears by it self
but the shift kit will fix that and the oil cooler i have coming will help with the s/c temps and i should be getting started on the intercooler some time in the next two weeks
also i have a fresh set of tires coming that will help to since my peerless hr's are spentand nearing bald
Tuesday, May 24, 2005 8:31 PM
You should run with the tranny in full auto to see what the difference in times is. Also, if it takes that long for your tranny to shift, I think you might be needing a new one.
Click Sig For Pics
Tuesday, May 24, 2005 11:42 PM
i need this super charger
Wednesday, May 25, 2005 4:49 AM
well if feels like it is getting better but i am still going to go with the b&m shift improver for 38 bucks its worth it
Wednesday, May 25, 2005 7:40 AM
sinrocker wrote:well if feels like it is getting better but i am still going to go with the b&m shift improver for 38 bucks its worth it
i take it you have a 4 speed auto?
whats your transmission temps?
Friday, May 27, 2005 5:18 AM
i dont know it didn't come with a tranny temp gauge.....
Friday, May 27, 2005 8:31 AM
ohhhh boy..
i know... but if you are shifting a car manually, you should have a guage, aftermarket, to monitor your fluid temp.
operating range is 175-195 and i can almost garuntee you are going over that which can damage the transmission.
adding a shift plus will also raise line pressure, which will create more heat.... more heat will do damamge.
Saturday, May 28, 2005 6:07 PM
well i say @!#$ it i will just get a cooler with out even knowing the temps i will get the gauge later
Sunday, May 29, 2005 5:34 PM
I say we get a new Forum Emoticon where a newbie shoots himself in the foot ! lol
Sunday, May 29, 2005 5:55 PM
sinrocker wrote:well i say @!#$ it i will just get a cooler with out even knowing the temps i will get the gauge later
your call, brah.....no point in getting pissed at people trying to help you out....
just tryin to save you a transmission repair bill.
Sunday, May 29, 2005 9:02 PM
that is an arrogant assumption
i am not mad or pissed just saying...
if i was pissed i would tell you to f yourself
but im not piss so
ttyl
Sunday, May 29, 2005 9:37 PM
i really wanna find out how you all interpret "arrogance" via words on a screen...... i really do
Sunday, May 29, 2005 9:54 PM
it means your assuming my position
i am not saying you are arrogant i am sayiong that you are assuming how i feel
i want to know how you interpreted what i said. that brought you to the conclusion i was pissed
i was simply saying i will get the cooler now and the gauge later
nothing more nothing less short and sweet
and we will leave it at that before someone actually gets pissed
ok
