well my buddies on Ohio Tuning were telling me that i was running way too rich in the caravan on the way home from a meet. so, i would like to know if any of you have come across this problem? the only mods i have are 2 1/2" catback system and a filter, performance wise. i need some opinions on how this would happen, how to fix it and stuff. Please??? Thank You!! lol no really tho you guys have helped me out alot
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
turn up the boost !!!!!!!!!
nah i dont know what to tell you did you check it on a wideband to see how ur A/F is doing?
Thanx Charles
... correct fule mix under boost should be rich, around 12-13to one.
ive got exasut on mine ( rk header 2.5 in exasut back , no cat,) and mine smokes blackish gray WOT.
chris
'02 Z-24 Supercharged
I would like to know how he can say that you're running rich just by staying behind you? black smoke is not a sign of rich mixture since the cat is there.
Gilles
2.3 Ho
Mfk-223 wrote:I would like to know how he can say that you're running rich just by staying behind you? black smoke is not a sign of rich mixture since the cat is there.
Thats what I was gonna say, how could they tell Mat?
2012 numbers - 4SPD
AUTOMATIC!!
adam said that they could smell it driving behind me, and no smoke i dont think, well at least they didnt tell me.
2000 Camaro V6.
mine acts like any other boosted cars. black smoke at boost levels.......i like it, most people think my car is broken when thay hear the SC and think the motors blown when it puffs smoke whenever i get on it......
my a\f is around 13.4-12.9 to one .... not bad i think
chris
well i only have a narrow band sensor, but it always goes way rich when i get on it. And i can look in my mirror and see greyish smoke. Kinda makes you wonder, if the car is running that rich stock, how much more HP could you get if it had a better af ratio?
2006 Black Cobalt SS Supercharged G85
13.91@102.77
BOOSTD CARS ARE DIFFRENT.. take all you know about civics and NA cars and get rid of it...... example, vavle overlap..... BAD.
running lean.....BAD
14.5-14.9 to one..... BAD.
rich .. good. ( very good, it also helps the car last longer. )
if you dont bleave me try puting your 290cc injecters back in... see how it runs.
chris
i dont get any black smoke comen from mine when i step on it...
do you still have a cat?... and also running a smaller pully will lean it out.
chris
Yep i still got a cat in there... and also still using the stock pulley....
I do have other problems with my s/c like a HUGE!!! vacuum leak that cause my car to die all the time just at idle.... and there is a 1-2 sec lag in power when i step on it... like i litterly do not move for a good 1-2 seconds when i put the pedal to the floor
get a can of TB cleaner.. find were that vac. leak is, when i installed mine ( ask jake) there were 2 studs at teh bottom of the manafold that my instructions said not to take out. any way, find out were the leak is, teh charger sould RIP, mine does
chris
Freebs wrote:I do have other problems with my s/c like a HUGE!!! vacuum leak that cause my car to die all the time just at idle.... and there is a 1-2 sec lag in power when i step on it... like i litterly do not move for a good 1-2 seconds when i put the pedal to the floor
These two things might be related.
If you've got a vacuum leak, it's likely that you're not building up the vacuum you need to close the bypass valve on the blower. That would account for this feeling of lag.
I get pretty much the same feeling if I'm under 3000 rpm in 2nd and give it around 3/4 throttle or so. It takes a second or two to build up the pressure to close the bypass and then kicks me in the back when it happens. It's kinda fun.
No issues at all at WOT though.
