Will this fit???? - Boost Forum
Will this fit????
Tuesday, May 17, 2005 1:26 PM
Hey guys,
Whenever I post in this forum in regards to my turbo setup I barely get any response.....either because it's never been attempted or attempted and failed and everyones given up hope, but here it goes anyway. I have an 03' sunfire and I recently got myself a turbo and manifold setup off a 9-3 Saab. I got everything I need except the downpipe, now I can chose to go with stock which i believe is 2.5" or I can go with 3".....my question is has anyone attempted this setup and if so will I experience fitment issues if I go with 3" which is a direct bolt on to the 9-3. My car will be lowered so the exhaust scrapping the ground is what I'm worried about.
Let me know.....
Re: Will this fit????
Tuesday, May 17, 2005 1:33 PM
Stock is definately not 2.5"... 3" will have some routing issues, 2.5" is plenty for moderate boost levels.
Tuesday, May 17, 2005 1:54 PM
my bad...I meant the stock downpipe on the Saab 9-3 is about 2.5" at least that's what I'm being told by the saab owner whose selling me the downpipe. So I guess 2.5" it is.
Thanks
Tuesday, May 17, 2005 2:19 PM
I wouldn't buy it, I doubt you'd be able to use it.
Tuesday, May 17, 2005 2:31 PM
why would u say that....I mean obviously the stock DP off the saab will not directly bolt up to our cars but thats nothing a exhaust shop can't handle.
Tuesday, May 17, 2005 2:38 PM
^ And by the time the exhaust shop is done with it, the only original thing on it may be the flange. The SAAB engine bay is a lot different than the Cavalier/Sunfire engine bay.
Tuesday, May 17, 2005 4:43 PM
yeah I was a feeling it's gonna be that way. So you think I'd be better off getting a flang and having a downpipe welded on it?
Tuesday, May 17, 2005 5:24 PM
Shifted, would this flange work...
Flange
.....assuming I was to weld a pipe to it and then make a U bend and feed down and through to the cat. And if so is there a gasket or something that I'd need to go in between the flange and turbo.
I appreciate your input on this one man.
Thanks
Tuesday, May 17, 2005 5:34 PM
As long as the turbo you have looks like the two housings in the pic on that auction, it should work. I'm really not sure if it needs a gasket or not, if it does, you should be able to get the gasket at any SAAB dealer since it would use the stock exhaust gasket.
