how hard is it to make it work ?
considering the map sensor, the faq did not mention any of this so i did read , and i dont see any other posts talking about this
I dont think it would be any different than putting a turbo on a manual
2012 numbers - 4SPD
AUTOMATIC!!
^ You'd think that, but you'd be wrong
Autos have far less room to work with than the manuals. I couldn't figure out a way to route my pipes over the engine, so I'm going under it. I'm also relocating my battery to the trunk for more room, and will be eliminating my A/C sometime soon as well.
MAP sensor shouldn't be any different than the manuals. Some people need check valves, some get away without it.
yea i figured a check valve was a poss. solution
anyoen with an auto with a turbo setup, post what problems if any u had and pics would be great, but yeah def could see an issue with clearance when working with an auto
other then my kit not fitting right and i had to rebuild the hole thing. only problem im having is fuel and exhaust leaks. i also have to figure out the timing too.
other then that its cooollllllllllllll.
member 1244or55
http://www22.ocn.ne.jp/~cavalier
problems like engine fires and such from not routing stuff properly? Been there done that. I have removed my AC, Rerouted my brake booster line. My heater core lines . My power steering lines. and my fuel lines. I have nothing back there anymore due to the fact I don't want another engine fire. Autos have no room to work with. So yes the install of a custom turbo kit is much more difficult to make work. Oh, and my battery is in the trunk too.
<img src="http://img.photobucket.com/albums/v292/dragmyz24/shoppedcav2.jpg">
Rush Racing
http://www.gettherush.com/
so it is a bigger task then first thought eh lol
migth be having second thoughts now
Mine is on a auto any questions just holler
<a href="www.daptronics.com">www.daptronics.com Huge Discounts on Electronics</a>
all fun and good projects call for some work...especially turboing a car idc if its auto or 5spd its all work and a challage but fun and pays off in the end. in the begingin i was like f*** this no im almost complete and each time i go back to do the finishing touch im so happy..even though like everyone said its more work on an auto ull love it in the end. but w.e u want good luck. im just sayin cause u get a curve ball thrown even tho u can still do it dont just stop..follow through.
speed kills, drive slow, drive a honda
You are what you Drive!
