Well im new to the org i just put it my new 2200 Turbo motor I have all forged internals,Custom grinded Cam, 1.6 Roller Rockers Pretty much completely built i finally got it in yesterday. When i turned it on it came on idled really bad turned off,Then i turned itt on and it idled at about 500rpm and turned of and finally i reved it it stayed on and just idled all over the place. I came back about an hour later i needed a break turned it on and it was idling at 3000rpm it it wouldnt come down so i turned it off. I have stock injectors and stock plugs. I have a cartech fmu and msd inline but i havent installed it because i thought i wouldnt need it to start the motor and let it idle i dont want to drive it till everything is in. Do think maybe the fmu or stock plugs are what is making it idle all over the place? Any help is aprreciated i will try to get some pics up soon all my mods are in the registrey.
i don't think your pcm likes your cam.
What can i do if the pcm doesnt like the cam i have the specs they are :
INTAKE:301
EXHAUST:292
Advertised Duration
270.0
264.0
your lift should be higher and your duration should be shorter... much shorter.
i think i read the card wrong Duration is 214 exhaust 208 Intake
i still think you should be making much more lift than that.
