I can get a guy to bend me some stainless up to 3.5 for my down pipe is that too big? I am planning on running that until after the cat where it then turns into 2.5. Should I go 3.5 for as long as I can or will I be reducing too much when I connect to the rest of the exhaust system? Oh and the cat thats gotta go right?
3.5" on a 2.4L, or a 2.2L eco is too large. Stick to 3" if you are running significant boost.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Why bend a 3.5" downpipe if you are only going to run a 2.5 from the catback??? Only run a 3" downpipe if you are going to run the 3"catback to support it. The rule of thumb is you can always go up in size on the exhaust for a turbo not down. So you can do a 2.5" downpipe to a 3" catback, but NOT what you suggested
No, the cat does not have to go. I have a 3" Magnaflow cat
Jason
99 Z24
#25 to register on the Org !!
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
the bigger the pipe the better...but go with that size the whole way through or go bigger after the cat like Jason said ^^^ its not a good idea to go down in size
anywhere in the exhaust, especially in a turbo car. so if you can fit the 3.5" under the car, go for it.
a high flow cat will improve flow. ditching the cat will improve flow even more.
_________________________________________
450WHP Turbo Ecotec swap in the works...
I don't know your setup but 3.5 sounds like overkill to me. 3 inch too!
95 Cobra
Check out my site
