Injectors - Boost Forum
Injectors
Friday, May 06, 2005 9:03 PM
Dose any one know what kind of injectors you can put in a 97 2.2
Re: Injectors
Friday, May 06, 2005 9:30 PM
None
The only option for running more fuel is doing a top-feed conversion or putting additional injectors in
Re: Injectors
Friday, May 06, 2005 9:51 PM
stock, or for upgrade, do like lowfire said.
I've done it to my 95. search top feed converision.
Re: Injectors
Friday, May 06, 2005 10:30 PM
Re: Injectors
Saturday, May 07, 2005 2:25 AM
Re: Injectors
Saturday, May 07, 2005 3:48 PM
Then what is all the other boosted 2.2 doing for fuel mods other than the top feed conversion?
Re: Injectors
Saturday, May 07, 2005 3:59 PM
Like I said man
You need an AIC (Additional Injector Controller)
You weld bungs into your intake system to put extra injectors in
Then you need to tune the hell out of it
Like this one: http://www.sdsefi.com/eic.html
Re: Injectors
Saturday, May 07, 2005 8:29 PM
Like im gonna do!
Im gonna run my 440cc injectors (2) into the intake pipe and run it with my MF2. I have the walbro 255 and accel fpr. I think its gonna work out great.
Re: Injectors
Sunday, May 08, 2005 5:33 AM
I was reading about the eic and would it be better to have a shop mount it on the manifold or right before the throttle body on the charge pipe?
Re: Injectors
Sunday, May 08, 2005 5:37 AM
Either way is fine
It has been done both ways and both work just fine
There hasn't been any "testing/dynoing" to see which works better
Re: Injectors
Sunday, May 08, 2005 12:51 PM
If i get big injectors will I have to do any other fuel mods needed to be done?
Re: Injectors
Monday, May 09, 2005 9:08 PM
Yes, usually, a FMU is a must if your going to boost, an adjustable fuel pressure regulator is good, but the stock one is already there.
Its good to upgrade the fuel pump to a higher one.
You can do none of this, but if you don't do the FMU, you're going to need some kind of electronics to add fuel as boost starts going in. Thats what a FMU does (Fuel management unit) it will add more fuel as boost pressure increases. even then, an SAFCII is recommended to fine tune it., and make idle nice.
