Ok again let me try this. I have a 01 Z with brown tops, rsm kit, cartech fmu, accell fpr, safc2,lm1 wideband, I wanted to know what my setting should be exactly. Not a/r correction but everything else. . I know in 5 out 5 and which way the throttle goes. 4Cyl yada yada but heres a list of what i don know.
1. In the etc menu the disp scale what pr should i use?
2. Same as above but what cr should i use?
3. My thr pt is at 10 and 50 Any suggestions?
4. When I start the car I it idles a little rough for maybe 5 sec then its normal.
5. The lm1 reads perfect a/f 14.7
6. I cannot see any changes in the lm1 no matter what I set the fuel to at idle meaning if I drop the fuel 40 % the lm1 reads 14.7 or if I set it to +40 % it does nothing. What could it be.
7. The wires are hooked up right the tach works knock works WTF.
8. My bfp is 35 and at 0atm 40.
Please let me know any suggestions to help me see a diff. Ive read that people can literaly hear the motor running more rich when they fatten her up but my wideband says no soup for you.
