Well, took the suggestion from Shifted(thanx bud) to change my s-afc2 to the 2 cyl setting and everything worked out! She started up with the same plugs, I guess she was just flooded last night or something. Anyways, she was idling like crap, so I adjusted it @ 800 RPM's, and you could actually feel the car running better with every drop in increments. My question is what are good settings to have it at, like percent wise...also, my intank fuel pump is whinning(it's brand new) is this normal? And it sounds like I have compressor surge when not in boost IDK though. A few little things here and there, some dynoing and it should be perfect! Thanx everyone for your help, much appreciated!!!!!!!!!!!!!!!!!!!!
P.S. tommorow is my birthday...Guess I gave myself an awesome gift
Failure is not failure if you learn from it
What is your base fuel pressure set at?
Pressure is at stock, it idles pretty good, but I can't floor it yet, it is bogging with fuel. However, even at quarter or so throttle and 5-6 psi it f-ing hauls!!!! I haven't quite figured out the whole s-afc2 hi-lo throttle crap yet, but after I get it streetable she's going in for a dynotune!
