IF (big "if" there) i deside to run a eclipse turbo (tdo5 14b) on my Eco running the stock amount of boost on the turbo (12-14psi), what should i put my fuel pressure at and what is the easist and cheapist way to do that? and where would you recommend getting the fuel mods from?
thanks in advance!!!
Fuel pressure needs to be increased according to boost, you can't just set it at 70 PSI and be happy, since when you are only at 2 or 3 PSI (or at idle even) you're car will run pig rich. You need to use an FMU.
Also, fuel pressure is decided based on the expected hp output and the injector size that you have.
recomend any specific FMU???? right now im running completely stock fuel system.
so that would sufficent enough for that turbo? and i really appreciate the help. im getting my turbo, intercooler, and bov next week, and probably getting custom piping bent the week after and i didnt wont to put it all on without any fuel mods.
