jumped timing + boost = bad - Boost Forum
Saturday, April 09, 2005 10:49 PM
well tonight i was getting on the freeway and my boost gauge went up to like 10psi when it is always 6psi, then my motor started to smoke bad and i pulled over coolent was everywhere, so i think i jumped timing under boost a blew the head gasket. the motors still run but it sounds like the timing is off
Re: jumped timing + boost = bad
Saturday, April 09, 2005 11:29 PM
weird
LE61T PTE6262 Powered
Sunday, April 10, 2005 12:05 AM
i doubt it jumped timing, if the chain jumped you would know about it as it would be protruding out of the side of the timing chain cover lol
ive seen these engines timing go and its not pretty its not like a belt where they can slip and jump to the next grove
i think you probably blew something else...
Sunday, April 10, 2005 8:09 AM
=OrangeZ= wrote:i doubt it jumped timing, if the chain jumped you would know about it as it would be protruding out of the side of the timing chain cover lol
maybe ill find out today
Sunday, April 10, 2005 4:10 PM
well it was only a blown head gasket. but why would it go to 10psi?
Sunday, April 10, 2005 6:32 PM
i would look at your wastegate before anything else
Sunday, April 10, 2005 6:45 PM
agreed. I didnt think the timing jumped either. If so you would have some bent valves.
Monday, April 11, 2005 7:19 AM
he has the gm s/c.
Monday, April 11, 2005 9:08 AM
are you using an FMU?
Monday, April 11, 2005 5:22 PM
KC Absolute Performance wrote:are you using an FMU?
not right now, i just running the ford brown top injectors at 55psi idle
