I was just wondering if any one has boosted a 2000 z24 without changing any of the engine internals I would like to know how much boost I can run safely and what size injectors should I use. If any one can direct me to a link on this forum where someone has their setup mapped out that would be wonderfull ,Thanks for any input
?I can't find anything on turbo charging the LD9 only ecotec 2.4L ,Maybe I am missing something obvious ....
Check my registry.
I have an all stock motor and push 11psi.
Car is still running to this day with about 22k miles on the setup.
Later,
Jeff
2000 Turbocharged Silver Z24 5spd
Cardomain Site
I say be careful dude, I was running 7psi for almost a year and 30k and I broke a piston land, stopped my engine pretty quick. But it worked well for almost a year, I would recommend pistons and rods, but that is just my personal thoughts. Maybe run a little richer and keep temp. down, that might help.. I also raced alot and really used my engine..
I apologize up front for another newbie question but when I turbo this car do I have to use gm supercharger 2 bar map sensors, injectors and reflashes. I don’t know anything about this this is what I have on my list as of now
manifold
Turbo
Intake filter, hks filter.
Oil inlet feed fitting.
Oil drain fitting
2 bolts for oil drain
Oil feed line
Oil feed line t fitting for block
Oil drain line
Oil drain fittings for both ends of the line
Intercooler piping
Silicone couplers and clamps for all intercooler piping
Intercooler
Flange for turbo outlet
Gasket for turbo inlet
Bolts for turbo outlet
Flange for end of downpipe
Piping for downpipe
Bolts for end of downpipe flange
Wastegate, bolts, flanges and gaskets
Silicone vacuum line for bov and wastegate
Injectors, 310 cc should be ok
Fuel pressure regulator
Fuel pressure regulator fittings
Walbro fuel pump
Fuel pump install kit
Greddy emange to control timing and fuel or something else to control timing and fuel.
Thanks for your input
Dave
You don't NEED to get the reflash, but it helps. Personally I'm not getting the reflash.
Here's my parts list:
2.3 HO Intake Manifold
Turbo Exhaust Manifold
.48/.50 T3 60 Trim Turbo
2.5" Downpipe
Downpipe gasket
Turbo O2 housing
5 2.5" Mandrel U-Bends
Oil Feed Kit
Oil Return Kit
Boost/Vac Gauge
A/F Gauge
TurboXS RFL Blow Off Valve
30x6x3 JRC Intercooler
Apexi SAFC-2 Version 2 (Black)
30lb/hr Ford Red Top Injectors
Ford Injector Harness
Cartech BEGI Billet 2025 Adjustable FMU
Accel Adjustable FPR 74565
Various oil T fittings
(Need to buy yet)
2 T3 Turbo gaskets
Exhaust Manifold Gasket
Intake Manifold Gasket
Oil Pan Gasket
90 Degree Weld Fitting for Oil Return
2.5" Straight Charge Pipe
8 Silicone Connectors
16 T-Bolt Clamps
Turbo bolts
Header wrap
I might be missing one or two things, but thats the majority of it.
I would say if you are using the map and injectors, then the reflash is a must. If using factory map then it not useful. It is really cheap to get the reflash (40 CND, 30USD) so it is a pretty nice way to aid in setting up fuel, a piggy back is still recommended though.
Sounds like you've really done your home work, with the whole parts list.
good luck
geforcez22 wrote:I would say if you are using the map and injectors, then the reflash is a must. If using factory map then it not useful. It is really cheap to get the reflash (40 CND, 30USD) so it is a pretty nice way to aid in setting up fuel, a piggy back is still recommended though.
good luck
Wow, where are you getting the reflash done for $30 usd??
Dealerships around here charge a good $100 for something like that...
Later,
Jeff
Cardomain Site
I just went to the local dealership, my friend who worked there said it costs about 35CND for a normal reflash, and for this one he ahd to call around a bit so he chardged me a little more.
it worked great
kinda sucks that I am selling my entire kit cause I blew my engine, such a waste of a good reflash.
Jeff-
GM cannot charge you for the software, but they can charge you for the labor. Its usually about 1 hours worth (even though it only takes 10 minutes), so depending on what dealer you go to, either they charge you the actual labor rate, or the book rate.
unless your friend works at the dealership, and helps you out on his spare time, we just paid to use the machine.
to get the reflash GM needs the last 8-digits of your VIN, and then they get a vehicle specific reflash, so all your factory options still work, I think it just gives them a record incase of warranty issues
