205whp/247tq @10psi on 91 octane - Boost Forum
Monday, March 21, 2005 9:28 AM
Well I dynoed the 03 on saturday and was pretty pleased. It's running WAY rich 10.X AFR through out most of the run. I'm also having some issuses with the HAHN plenum so I'll be going to some sort of 90º elbow on the TB. It would fly off the TB so we had to dyno with the hood shut. It's a good start with much more work needed. Just wanted to thank Eric R (97cavie24ls) for helping me get to where it's at now and Adam a local DSM guy.
Re: 205whp/247tq @10psi on 91 octane
Monday, March 21, 2005 9:32 AM
not to bad , im sure once the fuel gets straightened out it will be alot better , plus getting a less restricting exhaust will help too
even bill hahn jr was impressed when i talked to him at nopi this past weekend , considering how much of the stock exhaust is still on your cav
LOL
Monday, March 21, 2005 9:35 AM
Sweet!
Monday, March 21, 2005 9:55 AM
That's cool. I definetely want a ride in the car next time I'm down.
Monday, March 21, 2005 10:03 AM
AGuSTiN wrote:That's cool. I definetely want a ride in the car next time I'm down.
For sure man, but you have to buy something first
Monday, March 21, 2005 10:06 AM
Wow man
that must haul ass off the line
sounds fun good job
Monday, March 21, 2005 10:08 AM
I'm jealous
Those are some great numbers
Monday, March 21, 2005 10:13 AM
I'll take the yellow cav w/ the turbo you have in stock
Monday, March 21, 2005 10:14 AM
Nice!
Monday, March 21, 2005 10:55 AM
LOL @ agustin
Monday, March 21, 2005 11:28 AM
How many runs and how much did they charge you?
Monday, March 21, 2005 11:38 AM
2 pulls no tuning for $50. It was a dyno day setup by a guy on honda-tech.com
Monday, March 21, 2005 1:09 PM
awesome deal chad i remember talking to u on AIM shortly after u moved to CA and you had mentioned you probably would never turbo ur cavi, guess it doesnt count if u do it to another one Awesome #'s man
Dreams do come true....
<img src = "http://registry.gmenthusiast.com/images/96sunfireconvt/ModdedFireBlue.jpg">
Monday, March 21, 2005 3:16 PM
Your TQ is insane.
O noes!
Monday, March 21, 2005 5:03 PM
91 Ewwww. Get some better gas and go run again. 93 could give you 15-20 more whp. And then a run on 100 I am sure will net near 250whp on current setup.
Nice runs.
2004 WR Blue/silver STi
Monday, March 21, 2005 5:07 PM
91 is the highest we have at the pumps here in Cali. I wasn't out to make mad crazy HP. I just need to know where I was at. I'm just trying to accomplish a quick, fun, and safe setup for now.
Monday, March 21, 2005 6:17 PM
once you lean that out a bit you should pick up some good numbers though
Monday, March 21, 2005 6:52 PM
Correct me if im wrong but the octane of the fuel does add power per se does it, more that it allows you to increase the boost a bit more safely which in turn adds power, thats what ive always thought at least. Too bad tho Chad, back here in good ol MI i can get anything up to 110
Monday, March 21, 2005 7:19 PM
96sunfireconvt wrote:Correct me if im wrong but the octane of the fuel does add power per se does it, more that it allows you to increase the boost a bit more safely which in turn adds power, thats what ive always thought at least. Too bad tho Chad, back here in good ol MI i can get anything up to 110
you're correct, higher octane allows more boost/timing/compression which allows more power.
it's tougher to go leaner with the s#!t box fmu, he needs real fuel control next.
def some great numbers, needs exhaust and fuel, should make an easy extra 50hp on pump.
Monday, March 21, 2005 11:11 PM
Yes, its a means to an end. So ACTUALLY higher octane gas does get you more hp. Its kind of implied when one makes a statement like I did above.
Monday, March 21, 2005 11:29 PM
i never implied that you didn't imply. but hey, you're j-body owners -- what am i to expect?
Tuesday, March 22, 2005 7:50 AM
The numbers are ok fo0r 10 psi. I would expect more. I know of a ecotec J that dynoed on 7psi right at 200hp and 217 tq.
As for the higher Octane I do not think it will help because he has a very rich air/fuel already.
Is your FMU adjustable?
Still anice starting point.
Tuesday, March 22, 2005 7:59 AM
FstCavZ24 (Turbo ECO) wrote:Well I dynoed the 03 on saturday and was pretty pleased. It's running WAY rich 10.X AFR through out most of the run. I'm also having some issuses with the HAHN plenum so I'll be going to some sort of 90º elbow on the TB. It would fly off the TB so we had to dyno with the hood shut. It's a good start with much more work needed. Just wanted to thank Eric R (97cavie24ls) for helping me get to where it's at now and Adam a local DSM guy.
Sorry dude, I haven't seen your previous posts, but was that a Stage 1 or stage 2 Hahn kit? By the way, gratz on the numbers.
Tuesday, March 22, 2005 8:02 AM
^ Its a turbo kit....
Tuesday, March 22, 2005 8:10 AM
John is right, it is pretty low man for all the stress on your motor.
I know of another Eco that is putting 200+ or 7 psi
I mean mad props to you for hard work and stuff, but that fuel man, you are dipping in 9's with A/F which is waaaaaaaaaaaaay to rich. Putting that up to about 12:1 will give you about 20 HP for sure.
Let me tell you a difference between running mad rich like you are now and running good A/F, once you get your @!#$ straight you are gonna say:'' Damn, it felt like I was pulling a truck behind me with all that fuel"". lol
But again good #'s
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's ----12's ----11's ----10's
