hey just wondering where the best place to get these parts i have been looking at a few places, and i cant decide where to order from ... thanks guys
order a cartech/begi FMU pn: 2025 and you can run a stock FPR and use that FMU as a regulator for your baseline fuel pressure.
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/toond.jpg"></a>
you got a website for that....
stevefire wrote:order a cartech/begi FMU pn: 2025 and you can run a stock FPR and use that FMU as a regulator for your baseline fuel pressure.
Actually, you can only raise the base fuel pressure with the cartech, you can't lower it (based mostly where the FMU is installed). So you still need an FPR to set the base pressure.
You can get the Cartech 2025 cheapest on Ebay. I'm not sure if the Accel 74565 that the 2.4 guys use works on the 2200.
so you think the Accel 74565 is better than the cartech or dont it matter b/c i'm still going to need a FPR...
will that accell AFPR #74565 bolt onto a ecotecs fuel rail with no modifications? or will i need to modify it somehow???
