like it says what was the easyiest fuel system to work with if you run boost you need to tell those injectors to run a bit stonger. also do I even need a fuel controller for 5-8 pounds?
Kick azz is my boost hero!!! "
And by easiest do you mean ,cheap? easy tuning? easy to "hookup"?
The easiest and cheapest way is to use a cold start valve wired to a pressure switch.
For me I have found MS to be pretty easy.
i'm planning on running a MegaSquirt system as well.
