Help gm supercharger problem and need advise - Boost Forum
Monday, March 07, 2005 9:10 AM
ok....so i have the chance to get the gm supercharger for my 96 fire for pretty cheap.
but the problem is will it fit?...i know it will fit but the thing is i have had head work and
the intake ports were matched to the Ho manifold and opened up quite a bit.
and the gm supercharger has the lil rubber gaskets but i think thy wont seal right because of the bigger ports.
so should i get the adapter plate?
change the head out?
any ideas??
i need to know by friday where to get it or not
<img src="http://registry.gmenthusiast.com/images/snowman/thumbnail_sunfire.gif">
<img src="http://registry.gmenthusiast.com/images/snowman/thumbnail_personal_pic.jpg">
Re: Help gm supercharger problem and need advise
Monday, March 07, 2005 9:28 AM
it will work, my buddy bolted his right up, the only problem you will have is the egr and your starter possibly.. my buddy still has his 96 starter on.
and your pcm will need to be redone too
LE61T PTE6262 Powered
Monday, March 07, 2005 11:13 AM
know it will fit but the thing is i have had head work and ........and
the intake ports were matched to the Ho manifold and opened up quite a bit...
.....................but i think thy wont seal right because of the bigger ports
Monday, March 07, 2005 11:27 AM
Really, I couldn't READ?
Get the flange made to match or port match the S/C itself, anything can be done with some skill or money.
Monday, March 07, 2005 1:37 PM
only way to know for sure is to get the s/c and try it
Monday, March 07, 2005 4:31 PM
a flange wont work you will hit the radiator support
stick the s/c on there and seal it up with silicone you shouldn't have a problem
