how many people almost busted a nut the first time they drove a boosted car and heard that wonderfull spool and then bov?
i like my whine
![](http://img641.imageshack.us/img641/1227/sig1i.jpg)
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
ya but you dont get to hear a bov with that whine now do you! lol
Well i have never driven a supercharged car before... so this week end when my supercharger is all on i will let you know how i like it... I have how ever driven a turboed car with 30psi of boost... got to love the 87 Gnx
i dunno i love the sound of my supercharger over past turbocharge cars that ive worked on
it just sounds a hell of a lot meaner
s/c : gotta love the whine!
turbo: gotta love the bov and spool sound!
all in all i love both!
i want a superturbocharged cobalt ss! wonder how that would sound?
waaaaaaaaasssssssssssss pssss boom!!!
Shifted (KickAzz) wrote:I DO however, believe there is a direct correlation between PSI and happiness ![](/global/images/emoticons/ab.gif)
Most definitely.
traction always helps too
![](http://www.octal9.com/images/sigs/evo1.jpg)
Interior FAQ -
J-Body of Michigan -
Shifted (KickAzz) wrote:I don't believe there is a correlation between HP and PSI....
I would most certainly have to agree... especiall on a J-body!!!
- i refuse to ride in a car w/ a SC or boost.. untill i get mine.. b/c i know it'll drive me nuts till i do. LMFAO
![](http://i25.photobucket.com/albums/c92/twiztidtroll/trollsig09uc.jpg)
-Saint Augustine
turbos equals torque and torque equals fun, or something like that
the s/c is better
visual as to why
your sitting at a light , listening to a slight whine , guy pulls up next to you , looks over and laughs thinking your drivin a car with a busted part
he takes off , your along side of him , he speeds up and bit , you do the same , he lays the pedal down , you do the same the whine gets lots louder , and you beat the crapy outta him
the whole time your laughing , cause you the guy is thinking W.T.F. was up with that whine , and about that time it hits him like 20 tons of bricks , i got Fn beat a pice of crap
LOL
the supercharger doesnt whine at idle. Doesnt start to whine untill about 50% Throttle. This is due the TPS, the supercharger just keeps the bypass vavle open untill then. SO you dont make boost unless you get on the gas. This saves in fuel economy and allows you to drive your car normall and still retain good gas milage. But when you want to drop a fuel gallons, you just press a little harder onthe pedal.
But yes, the first time i drove my car with the supercharger i ejaculated all over myself. Luckily i was alone in the car.
2006 Black Cobalt SS Supercharged G85
13.91@102.77
So what exactly can I expect form My turbocharger?
1lb boost = 1lb of jesus juice
Kick azz is my boost hero!!! ![](/global/images/emoticons/jbo.gif)
^^^^^^^^^ guess you havent heard alot of super chargers in your life time
LOL
um superchargers have bovs too dont they.........?
![](http://www.teamethnix.com/ethnixcomsilver.gif)
98' Pontiac Sunfire SE
Exteranly mounted ones do. ^^^^ But as for the Gm s/c for the cav. no
-JaysonZ24- wrote:the supercharger doesnt whine at idle. Doesnt start to whine untill about 50% Throttle. This is due the TPS, the supercharger just keeps the bypass vavle open untill then. SO you dont make boost unless you get on the gas. This saves in fuel economy and allows you to drive your car normall and still retain good gas milage. But when you want to drop a fuel gallons, you just press a little harder onthe pedal.
It has nothing to do with the TPS... The internal bypass valve is mechanical and it triggered by vaccum.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
even though the by pass valve is open.. the supercharger gears are still turning....there for the sound will be there... but not as loud as when your around 3000rpm
shadow to bad your not boostin'
You have bass I have BOOST
dude i have the supercharger, trust me, it doesnt make any noise while idleing.
Are Eaton superchargers noisy? The Eaton supercharger system incorporates a specially designed bypass valve, which is actuated by a vacuum motor near the throttle body, and recirculates the supercharger air flow when boost is not required. During typical driving conditions, the engine is under boost around 5% of the time, which means the remaining 95% of the time the engine is under vacuum, allowing for better fuel economy and a quieter ride. In addition, the helix angled rotors, along with specially designed inlet and outlet port geometry, also reduce pressure variations resulting in a smooth discharge flow and a lower level of noise during operation. The associated ducting and mounting used in installing the supercharger can play a major role in reducing the noise emitted by the supercharger.
straight from eaton. I always get the supercharger info about the bypass vavle mixed up. I apologize. But still doesnt make any noise while idle, mine doesnt start to make noise till about 3,000 RPMS
13.91@102.77
i was wondering when someone was gonna point that out, not on the cav but soon to be on my laser. oh ya by like next thursday soon!
my s/c' makes some noise at idle, i love it.
not as loud as a Vortech blower though.
any form of boost is good.
eventually u will get used to it and want more and then you will add more (turbo=easy to add) and that will not be enough. the cycle never ends.
every SC truck ive ever driven or seen, has the whine at idle.
Fact 1:
true.
I drove a supercharged bonneville or regal (rental when I was waiting to get my cavy
)and I couldn't here the charger
It's just now cutting it's teeth.
I'd love to use the GM SC on my 99 and have the turbo eco too, best of both worlds.
