IS it better to buy a supercharger or custom order a friggin turbo cuz i cant find no pre made turbo kits for 97 cavalier, and since cavalier is a growing tuner car then shouldnt they have some made help me plz
I know i see that now sorry bout that i didnt realize where i was at the time wel i want all the horses ican push out of a cavalier at least enuf to beat new mustangs
well before this is moved, check out exploitedracing.com
or cavalierconnection.com
you should build up your internals before you go boost! Your car can only handle about 5-6psi of boost on stock internals.
Shifted (KickAzz) wrote:Why is this in the interior forum?
More importantly, why the hell is it still here? One would think a mod would've caught it by now.
Interior FAQ -
J-Body of Michigan -
agreed, mods are slaaaackkkkkiiiiinnn!
try more like 10-12 properly tuned.
It depends. Do you have a 2.2 or 2.4 Brandon?
1998 Cavalier Z24
Getting Boosted!
We offer turbo kits for 2.2L, 2.4L and Ecotec Cavaliers & Sunfires - your '97 included. The kits include everything you need: (Garrett) T3 turbo, header, down-pipe, charge pipe, (Bosch) blow off valve, (Tial) waste gate, (conical) air filter, hard water line, turbo oiling kit, vacuum lines and fittings, installation instructions and all mounting hardware required. The kits are true bolt-on installations requiring the usual hand tools (socket set, wrenches, pliers, etc.) and basic-level mechanical skills. The base kit is designed to run around 5 pounds of boost. The kit is capable of running higher boost levels but it may then be advisable to also use our optional fuel injectors, auxiliary fuel in-line pump, adjustable fuel pressure regulator and probably one of our intercoolers. In some cases, depending on engine type/condition and boost levels you want, it may also be necessary to install stronger pistons and rods - which we also offer.
Leo
CavalierConnection.com
5-6psi 10-12 psi Where the @!#$ are you people getting this from....try a lot more than that...SpeedRacerZ ran a 12.88 on 15psi and there are many people who have took a 2.4 to past 20 without incident...its all about tuning....granted there is a limit....head bolts stretching therefore taking out a headgasket or you could bend a rod due to the excess downward force...stock parts have their limit...but is by no means 5-10 pounds of boost....only if your an idiot and cant tune it
Goodbye Bobby, May God grant you the peace you never found in life.
�Here's my counter-offer to your counter-offer: go f**k yourself.�
�Al Swearengen
cavalier connection sounds good ill check it out thx
well said crash
<img src="http://registry.gmenthusiast.com/images/h8hondaz/sig.jpg">
I think IMPHAT is running up to 18psi on stock internals If I am not mistaking.
NfamousZ24 wrote:I think IMPHAT is running up to 18psi on stock internals If I am not mistaking.
highly NOT recommended.
^^^ why? if it hasn't broken yet I am sure its tuned well enough.......u people think engines are so fragile......they are not fragile to a person who knows what they are doing.....breakable yes.....I mean hell my engine is breakable, just because its forged doesn;t mean you cant burn a whole in it........but still....not fragile
�Al Swearengen
What are some other companies that offer reliable turbo's? Cavalier connections sounds pretty good, anyone have any experience with them? Also, how much boost is safe without having to go with internal upgrades for the Ecotec?
i ran 19 psi w/ stock internals for about 6 months...............then threw a rod
You have bass I have BOOST
ywlssport 02 wrote:What are some other companies that offer reliable turbo's? Cavalier connections sounds pretty good, anyone have any experience with them? Also, how much boost is safe without having to go with internal upgrades for the Ecotec?
Reliable Turbo's ???
If your concerned about being reliable I wouldnt' put a turbo on your car.
Reliable Turbo's ??? If your concerned about being reliable I wouldnt' put a turbo on your car
I just want to avoid a P.O.S. I have a low mileage newer car and I don't want to f**k it up too bad.
i will let u guys know when i get my kit from cavalier connection. i ordered akit and so far leo has answered all my emails and is a nice guy. and i will post pics when i get it installed. i cant wait!
<img src="http://www.j-body.org/registry/jay32m/personal_pic.jpg">
