i have a b.e.g.i. rising rate regulator and i read on some web sites that you should set the idle with the vacuum line left on the manifold. then i have also read on sites that you should always take off the vacuum line. now there is a difference in about 60 psi of idle pressure on mine. so what is the correct way. i would assume to tune it with the line attachted assuming you do have a check valve.
04 Sunfire with a hole in the block
Hahn Stage II
350 H.P. to the ground coming very soon
Is the begi a knockoff of the cartech fmu?
