Hey,
I was wondering if anyone could give me information on the injectors for the hahn stage 2 kit. I want to know if they are hi-impedence or low-impedence and how many cc's they are. Because I have the stage 1 from hahn already and I'm going to upgrade to the stage 2 on my own.
Thanks
best would be to contact them and ask
Yeah, the people who probably know most about the Hahn kit would be... Hahn.
I should have that info when HAHN gets back to me. I'll post up what I find out.
i doubt they will provide you this info, this question has been asked before they claim its a trade secret, you want those injects you most likely need to buy the stage II kit, or if you know someone who has it get them flow tested, best bet is to get somethign specific to your application
Thanks guys, I'll call them again. But if I run around 10-15psi on an ECOTEC what injectors would you guys recommend. I know RC make a good injector, I just got to know if they are low or high impedance and how big. I don't really need the ones from hahn, I just need one that works for my application.
Thanks again
they are most likely high imp sense thats what your car started with, also i hope ou deside to change your rods and pistons before you go over 10 psi .... not saying it cant be done because it has its just safer that way ...
i think they are accell injectors that can be had through jegs or summit for like 250$ for a set of 8. I am sure hahn buys them and makes a good profit on them. They are high impedence i believe and come in a variety of sizes.
i remeber them being yellow, and accell injectors are the only yellow ones i seen.(could be wrong).
Yes the injectors are yellow whether or not
they are accel i don't know
=OrangeZ= wrote:they are most likely high imp sense thats what your car started with, also i hope ou deside to change your rods and pistons before you go over 10 psi .... not saying it cant be done because it has its just safer that way ...
Ya, that's what I plan on doing, plus adding some kind of fuel or engine management
(any suggestions, because I can't find a decent system).
And I would rather go with RC then Accell. I'll probly go ask RSM in Mississauga, Ontario, and ask them.
Thanks
hahn has 32 lb per hour injectors.
04 Sunfire with a hole in the block
Hahn Stage II
350 H.P. to the ground coming very soon
i checked the box and they are high imp.
Hahn Stage II
JustinsEcotec wrote:hahn has 32 lb per hour injectors.
My price quote says 335cc inj, so yeah 32 lbs
