So where can i get or find decent quality T3 Turbo manifolds for the L61 motor with the ability to use an external waste gate?
"I like to burn money in piles too" -Brian
Hahn would be your best bet. Or zzp
Found the ZZP mani, probably will use that one. It is just a standard T3 4bolt pattern right? Same with the 38mm 2bolt wastegate flange, I can adapt a 38mm Tial wastegate?
looks like a t3/t4 pattern, I would call them and ask
Yup, standard. So it will work.
