I bought a aluminum flywheel to put on my turbo 2.3 quad4 I built for my chevy beretta gtz and I am ready to put the motor in but someone told that it would be a bad idea to use a aluminum flywheel on a turbocharged motor. Have any of you guys used a aluminum flywheel and had it fail and what should I use? aluminum or steel flywheel!
#1berettaman1991gtz wrote:I bought a aluminum flywheel to put on my turbo 2.3 quad4 I built for my chevy beretta gtz and I am ready to put the motor in but someone told that it would be a bad idea to use a aluminum flywheel on a turbocharged motor. Have any of you guys used a aluminum flywheel and had it fail and what should I use? aluminum or steel flywheel!
by the way my clutch is a stage 4+ and my goal is around 600hp.
Ecotec here but I have a twin disc clutch with aluminum flywheel. All that is different is that it revs and rev drops faster.
^^ and it accelerates the car quicker. if you know how to shift the dropping in revs shouldnt really affect it.
with as heavy as a quad 4's rotating assembly is i would definitely go for it.
M45/OS crank/2.4 snout. It's nice to be injected but I love being blown!
All the Fidanza and spec units that failed were from the first design. The second design is MUCH thicker.
Not to mention mine is a clutch masters!
