Ok so im doing my turbo install this weekend. i got the 255 pump in there already and i got a set of of colbalt green injectors. I was gonna just get a reflash from vince (trifecta) but found some one to tune it with hpt on a mustang dyno.
My question is if i put the injectors on will i be able to drive it or should i wait on the injector till i get to dyno drive is about a hour away. I just read in alot of post it could flood???? This is on my 02 ecotec
Thankx
*****BLAME IT ON THE ALCOHOL*****
I would personally drive it there on 0 to little boost while taking it easy on the throttle. Then just swap the injectors out at the dyno. Doesnt take that long to do. Just need a socket wrench, fuel line disconnect and maybe a screwdriver or pliers to get the clips off.
Or you could just tow it...
"You can only feed them semen for so long before their legs fall off."
I would agree, you really should change the constant at a minimum at best to drive it.
Ok that wut i thought just wanted to be sure thankx guys
